Thread: Engine Noise
09-29-2009 #1
New to Pro-Touring
- Sep 2007
- Baltimore, Maryland
- 75
Engine Noise
I just installed a set of AFR 195 64cc heads and upon firing up the motor, I have this noise:
I run a comp 270H and Rhoads variable duration lifters. These lifters require adustment like a solid lifter. I used a .020" feeler gauge, which is the street gauge. The first fire up I had noise on both sides of the motor. Yesterday I readjusted the valves and now it's only on the drivers side. I used an engine stethescope and it's definately coming from the drivers side valve cover. At first I thought it a rocker hitting the rocker drippers that are on the top of the valve covers, but I ran the motor with the covers off and it is still there.
Charlie Knudsen
67 Camaro RS/SS 350
