    Results 1 to 3 of 3
    Thread: idle problem
      stevensville mi
      idle problem
      I have a year one 350 crate with a quick fuel 750 carb with electrical choke which I had to remove to fit into the vortech supercharger cabinet. The supercharger is currently not hooked up. Took it on its' maiden voyage and all was well until I put the car back into park. In park the car progressively increased rpm and would not go back down by tapping on the gas? When putting it back into drive it ran fine.
      Any ideas why this would be increasing in rpm while in park?
      Jul 2009
      Atlanta
      I had the same problem, come to find out the cable attached to the choke was connected; however, it was installed improperly. This made it next to impossible for me to set the idle speed. The mechanic told me he sees it often and it is a common cause for idleing problems
      NH
      Your fast idle cam is still in action and needs to be set or removed if your not going to use it.
