      Lancaster,CA
      LS1 to Viper T56 ??
      Ok guys, I have a 67 firebird that Im putting a 98 Corvette LS1 in. I picked up a T56 with no bellhousing out of a viper for cheep. My question is what do I need to do to get the Viper T56 to mate to the LS1. I believe the input is larger/longer and what bell can I use? Any help would be great. Thanks, Jeff
      st. paul mn.
      you need to get the input shaft either out of an ls based trans. or order a new one from kiesler and then a ls based bellhousing as well as the frontinput bearing and i think that it .call kiesler they will know all the details i do have allt he part #s if you need i will try to find them.hope this helps. oh you will need a different yolk also for your drive shaft for the output is bigger.
      Oct 2007
      D&D performance http://www.ddperformance.com/ wil lhave everything you need. Your best bet is to sell it. too much work in my opinion. I have a viperized T56 from an ls1 car.
      Lancaster,CA
      Thanks for the info guys!
      Walla Walla, WA
      McLeod has everything you need to put your Viper T56 behind an LS motor. Take a look at this chart: http://www.mcleodind.com/application...L_HOUSING.html
      The two issues are that the Viper input shaft is longer than that of an LS1 (addressed by the use of the "scallop ring") and the Viper input shaft pilot bushing section is larger in OD than the LS1 shaft (addressed by the 0.75" ID pilot bushing). I'd call McLeod's tech line to confirm this will work, but you should be fine.
      You'll need a Viper slave cylinder because it's clocked differently than an LS1 slave, but that's not a big deal.
      No need to sell the trans you have.
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Nov 2004
      Colorado
      You just need an LS1 input shaft front plate and bellhousing. Total cost is less than $400 if you shop around.
