Thread: intermediate crank signal
I'm having trouble with intermediate crank signal so when I turn engine over the rpms are at 0 but when I let off the key it jumps up then right back to 0. It will not start with no crank signal. I have tried changing starter, disconnected alternator, pull one fuse at a time, reground battery to block and frame, 00 starter wire, disconnected the dfu's, disconnected the fans, tec unit is direct batttery power and grounded well.
I do not have and electric water pump and the crank wire is well insulated. If the spark plugs are removed it has a perfect crank signal. I done working on it for today and I try again tommorrow. Any help would be appreciated.
Allen Boston Ma.
68 rs/ss 335s, dse, 572 bb,nelson instake, 4l80, 4.11, becool, afx, bear, ultamate craco
