    Thread: porting heads
      porting heads
      Man,let me tell ya.Pontiac heads are the hardest to port ever.More twists and turns than you can ever imagine.Are big block chevys any better?I have porting my own heads for years with good results.I dont have a flow bench but i try to get each port to match each other.I think i need the next level.Any suggestions for a cheap flow bench?
      Nov 2004
      Roanoke, VA
      Old article from PHR (I think) on how to build your own.
      http://www.ag.auburn.edu/users/gparm...es/flowbench2/
      Flow bench discussion forum (lotsa info)
      http://www.tractorsport.com/cgi-bin/.../ikonboard.cgi
      Not as much info as above or as specific but still interesting reading.
      http://www.bikernet.com/garage/flowbench2-2003.asp
      I would like to build one some day as Im in the same boat as you since I need to step up to the next level but I have a LOT of projects to finish before I can even think about building one.
      GMC Syclone (currently wrecked thanks to the typical rubber headed VA driver not paying attention to his red stop light...oh and he didnt have insurance either)
      #614 11.9 @ 113
      New stuff finished 08/06:
      4L80E trans w/TCI PCM
      Syclone
      Tow rig
      Mar 2003
      Boringville
      i ported some pontiac heads, i didn't notice anything that hard about it, to me at least, they resembled small chevy ports
      McMurdo Station, Antarctica
      Lots of low buck flow bench info here: http://tractorsport.com/cgi-bin/foru.../ikonboard.cgi
      R.J.
      Pontiac intake ports are easy,its the exhaust ports that are hard.A lot of twists that are there.A lot of sanding rolls are wasted to do this.The exhaust valve guides are hard to narrow.
      Mar 2003
      Boringville
      valve guides? you must mean the valve guide bosses?
