    Results 1 to 11 of 11
      Jul 2009
      LS engine indentification
      Help. I have a new LS motor, but without any GM part numbers attached. It is brand new, and it came out of Australia from the GM plant down under. The number on the block is UF041211388. Can anyone help to ID...???? Thanks.
      Sacramento, CA
      what number sequence is on the heads on the exhaust side towards the end of the casting. Might be 241, 243, 317 etc.
      Dave Smith
      29 Ford Roadster Pickup blown 327 and stupid
      67 Chevelle 396/5 speed PT
      65 El Camino L79
      Jul 2009
      the casting number on the head is 241. Any help to ID..?
      Pensacola, FL
      Most likely its an LS1 99-up with that head. Every LS block I have seen here has the liter size on the rear at the top near the bell housing area. Not sure if they differ from australia and if they mixed/matched different blocks/heads. Have any pics?
      Scott
      Jul 2009
      pics. Lets see if this works.....kind new at this.
      Jul 2009
      more pics. work in progress.
      Pensacola, FL
      Nice project! I didnt know the motor was in the car. You probably cant see the area i was referring to due to the firewall. I see the accessories are removed, they would also help identify it. Probably an LS1. Is the block aluminum? It looks to be from the pics.
      Sep 2008
      Kathleen, GA
      looks like an LS6 intake manifold..that put's it at 2001+
      Jun 2006
      NW burbs IL
      Is that all steel? It looks like you will have to Dukes of Hazzard to get into it.
      Matt
      May 2002
      Southeastern WI
      Quote Originally Posted by tranny View Post
      Did you happen to see the back of the block before you put the engine in the car. It should have been cast with 5.7, 6.0, or 6.2 most likely. That would help you narrow it down.
      Jeff
      Jul 2009
      Thanks for all the input. I am leaning towards a 572 crate motor at this point. Yes, it is all steel......doors are overrated...!!!!! I'm 6'5" and wanted to do something different. No back seat, no top, no side windows, tons of leg room....should be fun if I ever get it done !
