Thread: 200-4r behind a ls1
09-14-2009 #1
- Feb 2007
- 199
200-4r behind a ls1
how well do you guys think a stock 200-4r trans would hold up behind a cam only ls1.
i know you're probably thinking,why?i already have the 200-4r in the car behind a l6 and i have the ls1 i bought for another project that won't need a motor for atleast another year.
the only thing i would need for the swap is v8 frame mounts,linkage kit for the 200-4r,computer tuned.
09-14-2009 #2I'm gonna say NO. The LS1 puts out more power when stock than any engine the 200-4R was mated with. Plus, there are a few versions of "stock" for the 200-4R, some not really performance compatible.
If you were going to drive it nice and easy I think you could get by, but a few shifts at full power and it'll be on it's way out.
If you do try it you will find that BTO does have a "TV Made Easy" kit that will work with the throttle body, so that's one concern you don't have to worry about.Jason Scheer
09-14-2009 #3
- May 2009
- 99
Depending on the year and type of car it came from, you will "find" (read: break) several weak points in the 200-4R. As Jason mentions there were several versions of stock 200-4Rs, the best ones being from a grand national and monte carlo SS, AFAIK. Early 200-4Rs had a weak sun gear shell, the splines would strip out. The later ones have a better sun shell. If you do decide to run a 200-4R behind a cammed LS1, you're definitely gonna need to rebuild with some stout upgrades, both hydraulic and hard parts.
Here's some more info:
http://www.jakesperformance.com/200-...uild_Tech.html
http://www.drwtransmission.com/thm_200-4r.htm
09-15-2009 #4
