    Thread: cam???
      Sep 2009
      lindenhurst ny
      cam???
      I have a 1970 chevy 355 4bolt Lt-1 motor that I bought used. The guy put this cam Lunati Street Master cam 08101 and a torker 2 intake 882 heads with shorty headers? What kind of power am I looking at and should I change anything? The car is an 87 monte carlo ss aero coupe with a t-5 trans and 3.73 gears. Will this cam be ok? The car is weekend driver. Future heads with be trick flow and I thinking about changing the intake to a performer air gap. thanks Rob
      Cam Style Mechanical flat tappet
      Basic Operating RPM Range 3,500-7,000
      Intake Duration at 050 inch Lift 248
      Exhaust Duration at 050 inch Lift 259
      Duration at 050 inch Lift 248 int./259 exh.
      Advertised Intake Duration 282
      Advertised Exhaust Duration 298
      Advertised Duration 282 int./298 exh.
      Intake Valve Lift with Factory Rocker Arm Ratio 0.528 in.
      Exhaust Valve Lift with Factory Rocker Arm Ratio 0.534 in.
      Valve Lift with Factory Rocker Arm Ratio 0.528 int./0.534 exh. lift
      Lobe Separation (degrees) 106
      Intake Valve Lash 0.020 in.
      Exhaust Valve Lash 0.022 in.
      Grind Number SM248-259
      Computer-Controlled Compatible No
      Lifters Included Yes
      Lifter Style Mechanical flat tappet
      Valve Springs Included No
      Retainers Included No
      Locks Included No
      Valve Stem Seals Included No
      Timing Chain and Gears Included No
      Assembly Lubricant Included No
      Pushrods Included No
      Rocker Arms Included No
      Gaskets Included No
      Quantity Sold as a kit.
      Sep 2002
      San Jose, CA
      That is A LOT of cam for a street car. Especially with the 106 Lobe Separation.
      If you want to keep that cam, the Performer intake is completely wrong, the intake will die right about the time you get into the cam.
      Do you know the compression of the engine?
      Just call me Brett
      that's a lot of cam like he said..
      even for the other mods you're gonna do.. You can get a away with it being a little over cammed since you have a clutch.. but that's exsessive..
      that cam would work well in say a 11:1 track 1, ect motor..
      The Gutless Cutlass, is no more.
      '73 Chevy C10, Low with lots of GO!!!!
      Sep 2009
      lindenhurst ny
      C.R. is 11-1 on the motor.
      Auburn, CA
      The 882 smog heads are very low performance and will hold up air flow. There are really affordable aftermarket heads that will come out of the box ready to run and handle your cam. The magazines use these heads to show how good aftermarket heads are. It is like using a Yugo to show how fast a Viper is.
      Tim Tracy
      Sep 2009
      lindenhurst ny
      So should I go with a victor jr intake and the trick flow super 23 street/strip head? Run a 4.11 rear to stay in the cam rpm range. Or just start over with a more street friendly cam? The car is not a daily driver. I might put 3,000 miles a year on it. thanks for your help Rob
      11 to one with the 882? that's a pretty big dome..
      do those mods and knock the cam down a notch and i'll be a lot better on the street.
      Sep 2009
      lindenhurst ny
      I'm going to break it down to a short block and build this thing the right way. I would love to know what he was thinking when he was building it. (heads intake ect.) And this was done at a machine shop.
