Results 1 to 1 of 1
09-13-2009 #1
Started installing a fan assembly today...
Well, I decided to go with a Derale fan assembly, and today I started putting it in. Last weekend I had tried mounting it to my radiator, but the dimensions weren't quite right, and the mounts they give you really don't allow any adjustment. (I should mention that this is a universal assembly, and was never claimed to be a direct fit. I don't know what radiators they designed it for, but mine isn't one of them.) Anyway, I changed direction a bit and decided to install the radiator and then mount the fans to the radiator support.
The first problem I ran into was that it wouldn't clear the steering box.
Okay, no big deal. I hadn't even considered that possibility, but now I know. (And so do you.) So I cut a piece out of the corner of the shroud (I only cut it about an inch deep, so I'd still have airflow), bent the ends of the piece so they'd face the other way, and then welded it back in the corner, but with it now recessed. Hit it with some paint which almost, but just doesn't look like the powdercoat they use, and I was back in business.
Now I've got it resting on the bottom flange of the radiator support with the lip almost lined up with the lowest tube of the radiator. Perfect! I'll just have to add some kind of seal to the lip, and that spot'll be airtight.
Now to the top: The radiator top cover/retainer hits the fan shroud. I expected that. The shroud is lower than the top of the cover, but higher than the mounting points for the stock shroud, and happens to line up almost perfectly with the top of the radiator. I don't have an actual plan yet, but I decide it'll be better to continue to modify the shroud instead of messing with the upper radiator mount. So, eyeball the obstructions, mark the shroud and go to town with the hacksaw. Now the shroud sits flush with the radiator and just needs to be secured.
I'm looking at the upper mount, and the holes for the stock shroud are behind the new shroud. I'm figuring that I can hold the shroud against the radiator with these and support it from the bottom of the radiator support. So, again I eyeball the location of the holes, mark the shroud and drill. The only problem is that the shroud is about 2-3/4" deep. Body bolts that would thread into the u-clips aren't long enough. I'm looking around the shop and can't quite find the right bolts. After looking at it all for a while I've decided that I really don't want to pull the shroud against the radiator anyway, so I think I'm going to make or buy some standoffs, bolt them to the upper mount, and then screw the shroud to them.
And that's where I've left off. I'll try to get some pictures next time, when I finalize the upper mounting and figure out what I'm going to do at the bottom.Jason Scheer
