    Results 1 to 9 of 9
      Aug 2006
      San Francisco, CA
      Impossible clutch fork alignment dilemma
      I can't find an answer anywhere on the 'net. I am installing a TKO behind my SBC. With the pivot ball set at 4.75" from the block surface, the clutch fork almost hits the front of the hole opening. It is impossible to get the boot over the fork without taking away all remaining travel for setting the air gap.
      Here is a picture of the clutch fork at a 4.75" pivot ball setting:
      In addition, the molded shape of the clutch fork boot shows me that the clutch fork should be way further back. But, at that setting, the pivot ball is distance is much greater than 4.75" AND the clutch fork would be really close to the firewall. Here's what I mean about the boot shape:
      Another picture of the boot:
      Here is the pivot ball at 4.75"
      I am stumped about what is incorrect... here is the full disclosure
      It is a special case installation, as I have a Ford-style TKO which has a longer input shaft than the chevy style. Thus, I have the special Lakewood adapter bellhousing they sell, 15030, which is a physically longer bellhousing than normal, which takes care of the longer length input shaft. I don't believe the bellhousing length would affect the clutch fork angle, as the pivot ball is still in the same position. And why does the boot indicate that I'm so far off? Any ideas please? I gotta get this one solved. Presuming the clutch fork angle is correct and I elect just not to use the lakewood boot...how can I effectively seal off the clutch fork hole?
      Other parts:
      Fidanza flywheel
      Centerforce dual friction clutch
      Mcleod adjustable pivot ball (adjust then cut to proper length)
      Jeg's clutch fork
      Here's a picture of the bellhousing length including the block plate: 7.125"
      Thanks very much,
      Steven
      Steven
      1968 Camaro: Project "TRACKDAY"
      Latest Track Weekend Video
      Build in Progress
      Aug 2006
      San Francisco, CA
      UPDATE:
      I'm giving up. Since the bellhousing is longer, the clutch fork runs into the floorboard/firewall.
      I'm going with a hydraulic clutch setup.
      Steven
      Build in Progress
      Central CA USA
      Don't count on that pivot ball measurement. Flywheels can have different thickness, so can pressure plates. There are different height throwout bearings too.
      David
      Aug 2006
      San Francisco, CA
      Here's a picture of the interference with the clutch fork and firewall. No room for travel and you can see that the clutch fork is being pushed forward by the floorboard, and resisted by the boot
      Steven
      Build in Progress
      Central CA USA
      Who's fork is that?
      I seem to recall a Lakewood fork won't work in a Camaro and only factory forks made for 1st gen's will fit.
      I'll see if I can find mine and compare.
      David
      Aug 2003
      David, he called me today and I do not think it is the fork in this case. He has a Ford bellhousing set up for a 7+ inch input shaft and the GM bellhousing is set up for a 6.5" shaft, so everything is moved back maybe 3/4", but even then the fork should be in the tunnel. Seems like the bellhousing is fat right there, fork sticks out too much. I told him to make the mechanical work, but he may be forced to hydaulic. Problem with is since the transmission is 3/4" farther from the motor, he has to find a hydraulic throw out bearing that is 3/4" longer then the correct GM / TKO unit and also has to fit the Ford input shaft. Maybe the Ford is already taller? I gave him some places to try.
      It is a special case to say the least.
      Central CA USA
      I was hoping if you got the pivot ball in the right place, the fork would wind up in the correct position regardless of the bellhousing.
      Here's a pic of my stock 67 fork. Note how it is trimmed narrow compared to the one you are using. I think it's trimmed this way to clear the firewall on a first gen Camaro. The top lip is shorter than the lower lip but both are more narrow than yours.
      My pivot ball is at 4.75" but I was not using a block protector between bellhousing and block. I think the plate is .200" thick so yours would have to be 4.55" to equal mine. My throwout bearing is 1.235" from end to end. Bellhousing flange to forward edge of fork hole is 3.5" on my Lakewood for Muncie setup.
      Read this thread: http://www.camaros.net/forums/showthread.php?t=70094
      Rockford Illinois
      Quote Originally Posted by sik68 View Post
      UPDATE:
      Getting the geometry to work and still have clearance would probably require you to modify the fork which leads to integrity problems if you weld it together.
      You will be just as happy if not happier with a hydraulic setup. Packaging is a lot easier and the bellcrank is no longer a part of the issue either.
      If you decide to go hydraulic and can get a few dimensions to know what you can use for a hydraulic throwout bearing I have a Quarter master throw out bearing I can give you the dimension for and if it would work for you I would sell it to you for $100. You will have to really make sure what you need for stroke and the amount of space you have available since the Quartermaster is larger than most hydraulic throwout bearings but since you seem to have the room it just might work ?
      Let me know and I can get you the dimensions of the one I have. I am busy thrashing to get my car on the road but you are going to have a complete custom setup by the time you are done it seems and who really know what will work until you get all of the physical dimensions figured out.
      This is going to be interesting to say the least when you get Dave and Frank helping you. You are in good hands here and somehow it will all work out.
      I also have a Corvette fork that is the same dimensions as Daves fork but it has a place for a rod and pin setup instead of the cup and spring setup and is a bit easier to work with.
      Keep us posted and if you need to ,send me a pm as I might not see the thread because of time.
      Aug 2006
      San Francisco, CA
      Thanks you guys. I really am making it hard on myself with this adapter bellhousing I bought (since I found this Ford TKO used on Craigslist, it seemed like a good idea at the time).
      I played with so many different pivot ball heights to locate the clutch fork, and basically:
      <>Setting the pivot ball long, ~4.75" away, the fork would thus be very far forward as in the pictures, and technically would work
      BUT the boot will be impossible to get on, so I don't know how to seal up the area. What is the stroke/travel of the fork? Maybe I could set it far forward, and when depressed it wouldn't hit the firewall.
      <>Or, I could set the pivot ball short, ~5.5" away, such that it fits the boot, and I wind up with the interference I show in my second post above.
      I am now down to 2 ther options that I can think of:
      1. Hydraulic Clutch with hyd. throwout bearing
      This could be a great solution, but as Frank advised me, it is not a sure thing that I will find a throwout bearing that is compatible with my mix and match of chevy and ford parts. I plan to talk with McLeod and Keisler, since they both offer a Ford TKO hydraulic throwout bearing.
      2. Replace the Ford input shaft with GM length shaft, and buy a different bellhousing to completely reset to a normal TKO swap
      Anyone know if it's easy to replace that input shaft? Is it as simple as taking off the bearing retainer and sliding it out/new one in? Here is the exploded parts diagram of the TKO (on page 3) :http://www.ttcautomotive.com/English...ice_Manual.pdf I am guessing I can buy an GM input shaft, GM baring retainer, and buy a new bellhousing for about the same price as converting over to a hydraulic clutch setup.
      Thanks you guys, all of this input is very helpful...keep it coming!
      Steven
      Build in Progress
