    Thread: Zbar removal!
      GA
      Zbar removal!
      Is there an easy way to remove the zbar? I need to pull the zbar out in order to get my drivers side header out.
      Kevin
      Canton, GA
      1968 Camaro "Project Achilles"
      Mar 2003
      Kirkland, WA
      If you are pulling the engine anyways, just start pulling it out, the z-bar just pops out.
      James
      -1969 Camaro Sport Coupe
      -1996 Z28
      -2005 Silverado
      Webpage
      Sep 2001
      Accord, NY
      I can just get to the nut on the frame bracket from the engine compartment; then undo the linkage and it pulls out. It was easier when I had the oil filter off.
      68 camaro - SOLD
      dennis68 Guest
      I back off the lock down on the frame bracket, and disconnect the linkage from the pedal then pull the zbar and lower linkage together.
      GA
      Thanks!
      Thanks guys I will give this a try tonight.
      Kevin
      Canton, GA
