Results 1 to 11 of 11
Thread: brake seizing up
09-09-2009 #1
- May 2007
- Midwest City, Ok
- 306
brake seizing up
First off I should mention this is on my 2000 Chevy 1500 pickup w/ 110k miles. I noticed a couple months ago a buring metal smell (smelled like you where cutting or griding on metal) that got more frequent. I then noticed that going from a stop to a roll it felt like the front passenger brake was seizing, since the problem was intermitted I drove it a couple more days with no problems and but I noticed smoke coming from the rotor and what looked like hot molted pieces of brake pad dripping down on the wheel after parking the truck. I then took everything apart and replaced the caliper, front pads, new fluid, and had the rotors turned. Well today after 2k trouble free miles on the new setup I smell the burning smell again and see smoke coming front the fenderwell/rotor area. Could anyone please guide me to the next correct step before I have worse problems.
Thanks Dustin
09-09-2009 #2
- May 2007
- Midwest City, Ok
- 306
I was thinking that it could be the soft line, the outside line show no wear but I guess there could be break down internally. If this was the case would the crappy line let fluid through under pressure but fail to release the fluid quickly and cause the pad to rub the rotor just long enough to cause problems?
09-09-2009 #3
