      Oct 2008
      LS7 Swap into 69 Camaro?
      I have been talking with Nordstrom's about their EZ2Run kits and I finally got a grocery list from them. For those that have done an LS swap....Do you see anything missing on the list beside a driveshaft and fuel tank that is missing?
      I got a grocery list of what is included for a LS7 swap....
      New GM Performance 7.0 LS7 with fuel injectors, stock exhaust manifolds, Factory Intake Manifold, Balancer and Flywheel
      All Engine Sensors
      Water Pump
      Vintage Air Polished Front Runner Drive Kit
      EZ2Run Harness with 3 wire hook-up
      Engine Computer
      Modified Road Ripper Transmission - 4L85E
      Oil Cooler Lines and Oil Tank
      Corvette LS7 Engine Covers
      Driveshaft Yoke
      Transmission Mount
      Engine Mount Adapters
      Fuel Line Adapters
      Anything else that anyone can see that is missing?? Thanks.
      PS: To go to an LS3 would be about $7000 less than the LS7.
      69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, QA'1's, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
      Jul 2009
      Phx, AZ
      Quote Originally Posted by g356gear View Post
      Add that $7k to the LS3 (turbo) and make LOTS of power
      Chris H.
      1965 Pontiac Tempest
      2005 Pontiac GTO
      Burnaby, BC, Canada
      I would think you would also need:
      Headers, oil pan and a stand alone PCM & wiring harness.
      1969 CAMARO RS
      Project pics of my '69
      Lateral-G Feature Page
      Oct 2008
      Quote Originally Posted by Rybar View Post
      They do supply an ecu and their own wiring harness with the kit.
      Aug 2003
      You need a radiator.
      Ahh, I missed the oil pan, Looks like the ECU is included.
      As I mentioned, I would do a roots blown (Harrop or MagnaCharger) L76 or L92. More power, less money, easier to install, more wow factor.
      Nederland, CO
      Is there a fuel pump on your list??
      I've also been considering a similar setup, but I thought the LS3 with the hot cam upgrade (GM 19213229) is like half the price for just a little less power. There is something cool about an LS7 though isn't there!! Fun!!
