      Eastern Virginia
      LT1 Guideplates?
      Which ones to use? I have tried both Comp Cams & GM ones & both allow the roller tip to be about half way off valve tip.
      Any suggestions/
      Scot
      86 Monte SS
      Zelienople PA
      I used the Comp's in my last build, but didn't remember them allowing the tip to move so far off the valve tip.
      1969 Firebird 400, Pontiac Powered 585HP/565TQ, TKO 600, Bonspeed Big Blocks, Nitto 555's, Hydratech, Speedtech Control Arms, QA1 Coilover conversion kit, other stuff
      Dunwoody, GA
      Are you sure you have the correct length pushrods, Scot? I've used Crane and Comp before and have not witnessed what you;re describing. If I am understanding you correctly that is.
      Trey
      ~ Jon Hammond
      Eastern Virginia
      Yep they are the right length, the tip is centered on the stem like this:
      But the rocker arm is allowed to pivot on the stud so the roller is not centered side to side.
      Later I will take the valve cover off & take a pic if this isn't clear.
      Scot
      86 Monte SS
