      Papillion, NE
      Intake temp sensor (Air charge temp sensor) location
      My Mass flo kit originally had the air temp sensor in the air cleaner.
      I am considering either putting it in the plenum or out on the radiator support. I have done both with Mopar Magnum motors in the past.
      Only reason is for a cleaner install. Any opinions?
      70 Mustang - 489 cid FE, KC ported Edelbrock heads, Modified Victor Intake, Mass-flo EFI, Erson valvetrain, Supercomps, TKO-600, 4.10 9 inch.
      71 F-100 4x4 SB 4x4, 461 cid FE stroker, Edelbrock Pro-flo 4 EFI
      13 Ram Laramie 2500 4x4 6.7 diesel - trailer puller
      The IAT is used by the ECM to determine the temperature of the air that is ingested by the engine. The closer you can get it to the intake valve, the better, so the manifold plenum is the ideal location.
      jp
      ​John Parsons
      Agreed. X2
      Aug 2005
      Patterson, NY
      So, drilling and tapping a hole in the manifold is not a bad idea?
      I was contemplating putting a hole in my manifold just under the TB, between where the runners meet the plenum. Wasn't sure if there would be issues.
      Jason Scheer
      I drilled and tapped a hole in my plenum directly under the TB. It worked fine.
      jp
      ​John Parsons
      Aug 2005
      Patterson, NY
      Excellent! Thanks!
      Jason Scheer
