      Crown Point, Indiana
      Disc drum to disc disc
      Just as the title says added disc to the back now I feel like I have some brakes but not what I expected I have to almost pump the pedal to stop. Do I need to change the MC? What should I change it to? Have a Kugel Komponents set up with a corvette MC. I think the piston size is 1"
      http://www.kugelkomponents.com/produ..._reverse90.php
      Jul 2009
      LBC
      When converting from disc/drum to disc/disc you need to remove the combination valve, and add a prop valve. You can add a prop valve externally, or install a MC with an integrated prop valve. I recommend using an adjustable prop valve if you have a "mismatched" setup so you can dial in your rear brakes.
      The spongy pedal feeling may be air still trapped in the brake system. If you can pump the pedal a couple times quickly and get a stiffer pedal as you go then there is likely air trapped. Your pedal travel will increase a bit because you are displacing more fluid with the caliper pistons than you were with the wheel cylinders.
      You may not notice any difference in stopping power with rear discs depending on your setup. The difference shows up when you get some good heat in your brakes. You also need to burnish your pads properly to get all the performance from your new brakes.
      Oregon
      In looking at the link you provided, are you running power or manual brakes? If power, the single 7" or dual 8" vacuum booster? Pressumably this is on your Nova? What front and rear disc brake calipers are you running, including the piston diameters if you know them? Are you running parking brake calipers in the rear? If so, what type? Air in the system and/or improperly set up parking brake calipers can create the symptoms you describe with needing to pump up the pedal.
      In general, most early GM disc/disc manual applications use a 1" bore MC, whereas the power disc/disc applications used a 1-1/8" bore MC with a variety of different boosters and pedal ratios depending on the application. 6:1 is pretty common for manual and 3.7-4:1 for power brake cars.
      Tobin
      KORE3
      It's what I does.
      Nogo,
      I am trying to keep everything branded.
      Tobin,
      I am running power brakesw/ 8" booster. With Corvette M/C (have not checked piston size yet I think it is 1"))
      Yes this is my Nova.
      I am running DF 202-P-K From Heidts Wilwood w/11" rotors It doesent really say the caliper piston size.
      Rears are also Wilwood 12" rotors with Dynalite 4 piston caliper ( no size for piston)PN# 1402117-P-B
      I am not running parking brake calipers.
      I am also running a Wilwood adj. proprotioning valve
      And just checked my vacuum at the booster it is between 8-10inlbs
      Should this be around 18-20?
      So. Cal.
      Hey Tim. Im not familiar with using a vacuum booster and a blower. But I would bet there are some considerations. Thing about wilwood brakes is they actually give great performance with an un-boosted MC. They have some really nice setups for MCs too, check thier web site. Or call them, pretty informative folks. They just happen to be in walking distance for me. But if yer set on a power brake system you may be hard pressed with the low vacuum.. JR
      Oregon
      Without caliper piston areas, I can't really say what size MC you should have, but your vacuum levels are sub-par for sure. Ideally, you'd have 16+ inches of vacuum at idle for the booster to work as intended...12-14 is getting marginal...and below that tends to be a good time to swap to manual brake IMHO. An alternative would be to run some sort of vacuum pump, but by the time to add up the cost of that and an accumulator, you could've swapped to manual 2X over or even considered hydro-boost if you really want power brakes.
      Tobin
      KORE3
      It's what I does.
      I really dont need power brakes. I am just looking for a combo for this car that I can safely and autocross it.
