      Jun 2009
      Decatur, AL
      t-56 measurement question
      I just need to know the distance from the transmission mount flange to the center of the output shaft's center going height wise. Mine's up under the car and I'm not sure if I'm getting it right but I think I'm getting 3.25 inches. If someone could verify this for me it would be great. All of the schematics I'm seeing on here and other sites mostly give lengths and widths with no heights.
      2001 Camaro Z28 (DD)
      LS3 525hp GM crate engine, built 4L60e
      1974 Camaro Z28 Type LT
      Solid roller 355 sbc with T-56
      Walla Walla, WA
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Jun 2009
      Decatur, AL
      You're talking about the "F" reading with the 3.75 right? I think that's from the bottom of the bellhousing to the transmission mount's mounting surface. I need from the transmission mount's mounting surface to the center of the rear output shaft in height.
      Walla Walla, WA
      Quote Originally Posted by kyphur View Post
      You may be right, although that's a pretty useless dimension for them to collect and publish.
      Jun 2009
      Decatur, AL
      They probably think that the one I'm asking for is a useless dimension to measure, ha ha.
      Boonville, Missouri
      In looking at the Tremec mini-catalog is looks like 3.4 inches on the T-56 and 3.1 inches for the T-56 Magnum.
      Tony Edler
      Illumin8s
      '73 Dodge Challenger
      Jun 2009
      Decatur, AL
      Cool, thanks!
