Thread: valve stems rubbing
04-02-2005 #1
- Aug 2004
- 281
valve stems rubbing
We mounted the wheels and tires 17 inch intros. the valve stem hits the front calipers Baer 13 inch. Is there a fix ? flush valve stems ?
thanks
Brad
04-02-2005 #2
- Aug 2004
- Connecticut
- 847
I had some flush valve stems on my 68 camaro the kind that had a screw that you had to undo to put air in or out of the tire. the problem i had with them was when i tried to unscrew them after they had been on the car for a while it tore the rubber seal apart and the tire went flat in a couple of seconds so be careful with them.
Paul
04-02-2005 #3i had a similar problem . mr. gasket has a shorty bolt in valve stem under a 1/2" tall w/cap the nuts that hold it are on the inside of the rim. if i remember right the part number was #1957 but i'm not sure on that better double check.
04-03-2005 #4
- Aug 2004
- 281
Thank you for advice, will look into it.
Brad
