    Thread: 9 inch problems
      Arlington Heights, IL
      9 inch problems
      my rear end is acting weird. it is a posi with 4:11's. it chirps around turns all the time. When i take off you can feel something engage. kinda feels like a trans slipping and then all the sudden engaging, it jerks a little bit. also, when i shift around a turn the car kind of steers funny. everything on my car has been replaced except this rear end. should i just get a new posi unit?
      thanks
      Jesse
      1969 Camaro under construction.
      1967 firebird. 6.0/t56. Ridetech stage 2. Moser 9 inch. Forgeline wheels.(SOLD)
      I need to know what is in it now. Is it a factory Ford Traction Lock? If it is then you need to remove it now and inspect it. These differentials have a weak side cover on them that breaks and can cause major rear end damage. If the cover isn't broke then you need to disassemble the differential and inspect the clutches, left axle gear and the 4 pinion gears for damage. If this problem has just started then don't keep driving it like it is. Check it out before any more damage is done.
      Broken side cover on the Ford Traction Lock.
      yeah this problem has been here for a while. could this cause wheel hop? i have horrible wheel hop and good suspension. i have had the rear end apart but nothing looked broken but im no rear end professional so i might have over looked it.
      Aug 2009
      Chandler, Az (from west NE)
      Are you using a limited slip additive, or straight gearlube? Concerning wheelhop, what do you have for shox?
      Ric
      Ric
      2002 s10, DD and AutoX.
      1966 Malibu owned since 1971. Drag car converting to track toy!
      yeah i do have the additive in it. i have bilstein hps shocks and dse leafs
      If the clutches are set up too tight in the Traction Lock it will pop when turning. You can't set up the clutches as tight in one of these as you can in an Eaton Posi.
      Aug 2009
      Definitely a decent reas suspension set-up. Pinion angle maight be another thing to check. Needs to be down in relation to the driveshaft, probably at least 2 degrees + with the manual trans.
      Ric
      Niceville, Florida 32578
      Sounds like a normal Detroit Locker to me. Sure you don't have a locker differential in the rear instead of a Trac-Loc?
      All that is necessary for evil to succeed is that good men do nothing.
      Edmund Burke
