Thread: Hot engine - no start
08-28-2009 #1
On hot days when my bigblock gets up to temp, it does not start. It's not all the time, just occasionally. When it does it, I don't even get a click out of the starter. If I wait 15 minutes, it starts right up. Is this a case of a starter issue or just excessive heat from the headers on the starter that could be answered with an insulator wrap on the starter? Thanks for any feedback.
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, QA'1's, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
08-29-2009 #2You are almost certainly overheating the start solenoid.
Get a Moroso Heat Shield and you'll be fine1971 Camaro, 383 stroker ~500HP,M21 Trans with lightened flywheel. All Sorts of Auto-x Goodness in the Suspension. 12" Brakes ->SOLD
Just call me Brett
08-29-2009 #3
- Oct 2004
- Papillion, NE
- 203
I agree completely, lack of a click means the solenoid is getting hot. Sometimes if its real bad, a little strategically positioned header wrap can help too, as can ceramic coated headers if you dont already have them.
70 Mustang - 489 cid FE, KC ported Edelbrock heads, Modified Victor Intake, Mass-flo EFI, Erson valvetrain, Supercomps, TKO-600, 4.10 9 inch.
71 F-100 4x4 SB 4x4, 461 cid FE stroker, Edelbrock Pro-flo 4 EFI
13 Ram Laramie 2500 4x4 6.7 diesel - trailer puller
08-29-2009 #4If all else fails, a couple of companies offer remote solenoid kits.
Just call me Brett
08-29-2009 #5Yep, it's heat soak. Solenoids don't like to work properly when overheated. There are basically two solutions; prevent the headers from overheating the starter, and getting a remote solenoid installed. I think both are good ideas, and neither one is very expensive. Remote solenoids kits are under 30 dollars, and if you can source a ford remote solenoid and do the wiring yourself it's damn near free. I suggest trying the heat shield/header wrap first, and if that doesn't nail the issue install the remote solenoid. If you installed the remote solenoid first (like I did on my cutlass), even though it will probably start like new every time, get a heat shield on the list of things to do. Overheating it like that can't be good for starter life, and replacing a starter with headers in can be a real PITA.
-- Dan
08-29-2009 #6I picked up a Thermotec starter wrap today to try. We will see if that does the trick.
09-02-2009 #7Wayne S
79 Pontiac Trans Am WS6
krepower.com Aluminum MR-1A Pontiac 505cid
04 Ram SRT-10 Viper spec Tremec T-56
no idea for suspension yet....
Year One billet snow flakes soon
SpitzKraft HID conversion kit
http://protouring79ta.monchar.com/
09-03-2009 #8
