    Page 7 of 8 FirstFirst ... 2 3 4 5 6 7 8 LastLast
    Results 121 to 140 of 169
    Thread: Pedal Talk
      Greenwood, SC
      Quote Originally Posted by Payton King View Post
      sizing on my masters one more time. Once you figure out what size you need drop me a pm. I have every size master that tilton makes that I have bought getting my brakes dialed in. I am now going for a 7/10 front, 3/4 rear. If that works for me, which I think it will, i will have 5/8,7/8 and a 1 inch that have a few miles on them.
      What brakes calipers will you be running on your car? What pads? Pedal ratio? I may be able to help you get close on the sizing.
      Awesome Payton! I will definitely keep you in mind. I am still trying to figure out my MC selection (and I thought that the balance bar was complicated....lol). It sucks not knowing the current weight of the vehicle and it is hard to calculate while in the air with no wheels or tires on it....
      The brakes are C6 Z51's from Kore3:
      Fronts - 340mm DBA 4000 slotted, Aluminum hubs, C6 PBR twin 45mm piston calipers
      Rears - 330mm DBA 4000 slotted, C6 PBR singe 40mm piston calipers
      I have also decided that I WILL be running an adjustable prop valve during street use that can be "turned off" for future racing events.
      I'm not sure on the pads.... whatever was in the bargain bin at Tobin's place lol
      JC Scott
      Charlotte, NC
      With a twin set-up
      and balance bar there is no need to the prop valve. You will size the master to your application and use the balance bar to fine tune.
      The brakes that you are using have the same piston area as the 6 piston wilwoods I am running on the front and the 4 pistons on the rear.
      Depending on the weight of your vehicle and your pedal ratio we are going to be pretty close to the same. I am going to guess that your car is going to be at least 3500 lbs so i would shoot for a pedal ratio of 6.5 to 7.5 :1. I would run as aggressive a pad as you can stand and not tear up your rotors. Hawk HP+ is suppose to be a good pad and not too expensive. I spoke to Tobin the other day and he turned me on to Carbotech. Come to find out they are located about 15 minutes from my house. I am trying there A6x pad. It is an autocross pad with great cold bite, which will be good for cold stops on the street. Suppose to be easy on the rotors but dusty and possibly noisy. Should have them on in a week or so and I will let you know what I think.
      I am changing my front master to 7/10 and keeping the 3/4 on the rear. I will take pressure readings for you as well.
      May 2007
      Las Vegas
      Rich
      1969 Camaro (in hibernation)
      Feb 2010
      If you haven't ruled out stock pedals, there is an upgrade you can do to the stock ones while restoring them. There is a bearing kit available for the clutch pedal shaft to get rid of the stock die cast zinc bushings with plastic inserts and replace them with smooth ball bearings. Smoother pedal that can handle a stiffer clutch. The kit is available from mustangsteve.com Check out his tech article on it. I just got a kit to put on my GTO. Just have to make sure the pedal shaft is long enough. I think a lot of the 60's pedal assemblies had the same dimensions of shaft dia and width. I put a kit on a 65 Comet awhile back.
      Greenwood, SC
      Quote Originally Posted by Brad_bb View Post
      If you read through this thread, you will see where this is exactly what I did...... It turned out well, but I haven't used it yet to see how well it actually works.
      JC Scott
      Feb 2010
      Doh! I only read the first page and didn't see the multiple pages. At least you guys do know about the bearing kit.
      Greenwood, SC
      The guys over at FordMuscle told me about it, so I contacted Steve and he assured me that it would work..... I hope it funtions properly. Should be better than it was!
      JC Scott
      TN
      Now that you have everything figured out let me throw my $0.02 in here. Another benefit to a prop valve over a balance bar is that you can adjust the F/R prop. on the fly. Which can be usefull figuring out exactly what you like and can be adjusted to suit changing track conditions. Just another thought for all those out there reading this. Btw... What is your friction surface on the pedals? bedliner or something? you might have already said but I didn't see it.
      Benjamin
      Twin Dusters
      Greenwood, SC
      Quote Originally Posted by Bjkadron View Post
      Are you talking about running a prop valve instead of a balance bar, or in conjunction with?
      The pedal "pad" is actually grip tape. We will see how long it lasts. Shouldn't have to worry about my foot slipping off though!
      JC Scott
      TN
      Quote Originally Posted by cheapthrillz View Post
      I was refering to just a prop valve. But I suppose it would work either way although you wouldn't have as much control over the turn in on braking as you would without the balance bar. I've been flopping back and fourth with what I want to do with mine but I'm actually leaning towards just the prop valve due to the "on the fly" adjustment and the better braking at less then full force.
      Nice trick on the grip tape that stuff is usually pretty tough... Let us know how it works out.
      Benjamin
      Twin Dusters
      Greenwood, SC
      The Front to rear bias can also be changed on the fly with the Tilton setup.
      I can't see a single reason to run a balance bar on the street, but since my car will see track time eventually, I decided to get one because it is the best system for racing.
      I am getting a prop valve strictly for use on the street so that my rear pads last longer.
      JC Scott
      TN
      I looked through the thread and I thought you were mounting it in the engine compartment? Were you saying that YOUR setup was adjustable or that it could be? I'm slightly confused. even so I can't see reaching to the floor or under the dash to adjust it while driving. Maybe I'm missing something?
      Benjamin
      Twin Dusters
      TN
      Oh thats cool! I hadn't thought about something like that! I think you just helped me decide!
      Benjamin
      Twin Dusters
      Greenwood, SC
      Awesome! Check out Tilton's website to get the part number. I think that Summit Racing sells it also. I'm not sure how long the cable is, but it should be long enough to put the control in a cofortable and accessable spot.
      I am going this route with both the prop valve and balance bar control in the future, but not as of now.....
      JC Scott
      May 2007
      Las Vegas
      I have a wilwood pedal set for my Chevelle and was thinking about this - mounting it at the center console...
      Wilwood Disc Brakes 340-4990 - Wilwood Remote Mount Brake Bias Adjusters
      Adjust front-to-rear brake bias while racing.
      Wilwood's remote mount balance bar cable adjusters are used with dual master cylinder/single brake pedal assemblies to adjust the front-to-rear brake bias during the race--without leaving the seat! They feature a bright blue knob for adjustment, and a modifiable 5 ft. cable and housing for easy installation into tight areas. They include two labels for bias identification and fit all balance bars with 3/8 in. x 24 threads...
      Rich
      Greenwood, SC
      ^^^^^^ That would probably work too.
      Here is the one from Tilton:
      Can be found here: http://www.summitracing.com/parts/TIL-72-408/
      JC Scott
      Woodstock, Ga
      Quote Originally Posted by MCMLXIX View Post
      I've seen lot of race cars use these in conjunction with the triple mast setup for on the fly adjustability. The key is getting the right bore size and tuning with the balance bar then use the prop to make small adjustments per track. This one is in a c5 ls7 car that was at the mitty.
      Robert
      (sorry for the large picture, it won't let me resize in the window for some reason)
      Greenwood, SC
      Quote Originally Posted by RS_Customs View Post
      Robert
      Damn Robert, I should have paid more attention to this kind of stuff while I was there! I didn't even think about looking at it..... I was too busy rolling my tongue back into my mouth every two or three seconds.... haha
      PS. Was this the black C5 that was running in the same class as the C6R?
      JC Scott
      Nov 2007
      Dayton, Ohio
      CNC has one also.
      http://www.cncbrakes.com/images/830.jpg
      Cheap,
      Finished my pedals & bearing conversion of my bracket a couple of weeks ago.
      Roger
      69 Mustang coupe, under construction
      2011 Mustang - DD
      https://www.pro-touring.com/threads/...ang-SuperCoupe
      Freedom Of Speed!
      Greenwood, SC
      Quote Originally Posted by 69stang View Post
      CNC has one also.
      Cheap,
      Awesome! Looks like it turned out well! What are you using for pedal pads? Also, is that a grease fitting that I see at the pivot on the brake pedal? If so, did you not get a sealed bearing?
      JC Scott
