    Page 6 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
    Results 101 to 120 of 169
    Thread: Pedal Talk
      Yes. 3/16" should be sufficient, since the bolts are just a couple of inches apart.
      jp
      ​John Parsons
      Greenwood, SC
      Time to get to welding then!
      JC Scott
      Greenwood, SC
      Oh, and thanks for all of the help so far JP!
      JC Scott
      Greenwood, SC
      Apparently building a steel bracket requires all of the tools that I don't have.... so now I'm looking for an air compressor and cutoff wheel to cut the plate steel.... I have a feeling I will end up spending more on tools instead of the car!
      And it looks like I will have to mount the aluminum balance bar frame upside down to keep fitment issues down.
      JC Scott
      Jul 2007
      Olathe, KS
      Quote Originally Posted by cheapthrillz View Post
      I have a feeling I will end of spending more on tools instead of the car!
      Join the club It seems like every time I turn around I'm buying new tools.
      Fortunately I'll have them around for the next project. The quantity of funds allocated to the car vs tools does seem to be increasing. Hopefully this signifies I'm finally reaching an end to the tool buying!
      Greenwood, SC
      I've got the mock up balance bar bracket started. It shouldn't look too pieced-together when I'm finished, but I will let you guys be the judge of that.... I'm going to work on it some more this afternoon and I will try to snap some shots if I can remember....
      JC Scott
      Greenwood, SC
      JC Scott
      Southern California
      Thats the beauty of buying the tools...there is a ton of steel out there to cut up and make killer stuff....
      Tools are there for the next project!
      May 2009
      Florida
      Clayton MachineWorks airframe pedals are nice but expensive
      Greenwood, SC
      Quote Originally Posted by killer67 View Post
      If you can prove to me that the performance value per dollar for these pedals is greater than 1:1, I will gladly buy them..... I thought I already spoke on this topic?
      Did you even read through this thread or just look at the thread title and have a word vomit?
      JC Scott
      May 2007
      Las Vegas
      Did you ever get the chance to take pics of the bracket you built? Did you mount it in the car yet?
      Rich
      1969 Camaro (in hibernation)
      Greenwood, SC
      Quote Originally Posted by MCMLXIX View Post
      No, I haven't done either yet. I'm working intently on getting my brakes straightened out. I'm having to turn down the axles, have hub centric rings made, etc.....
      I am kind of embarassed to post pictures of it.... It wasn't my best fab work (because I haven't done that much) and it looks like crap... lol
      But just for you, I WILL take pictures of it when I get off work today.
      I am going to end up building another bracket and just using the balance bar and swing arm off of the Tilton piece. I think it will turn out better if I do it that way.... hopefully.
      Aleast with the bracket I have now, I can get it mounted and figure out all of my dimensions.
      JC Scott
      Jun 2005
      Greenwood, SC
      It does NOT look like crap. It's just a very, very, very function-over-form design.
      Not for the bling-and-billet crowd!
      Mountain View, CA
      Good thread guys. Keep up the tech.
      True T.
      My blog
      Greenwood, SC
      Please don't laugh......
      JC Scott
      Mountain View, CA
      Well that weld is a bit under-penetrated but otherwise I don't see anything that doesn't look pretty darn good.
      True T.
      My blog
      Greenwood, SC
      Quote Originally Posted by Damn True View Post
      Tack weld.... lol
      I got mad when my small tacks broke while I was drilling...
      JC Scott
      May 2007
      Las Vegas
      I wouldn't laugh - I cant even weld so you're a few steps ahead of me...
      Does the bottom plate attach to the balance assembly? If not I think it may be dead weight.
      If you want additional support. I was looking at the pics in the endine bay. I think I see two bolts located on the firewall under the master cylinder. You coul use those to triangulate the fixture and support it....
      I made a quick MS paint drawing... its a side view and uses the plate you have that attatches to the firewall. The side plates are wider where it attatches to the firewall for more weld area. The other gray line is a flat bar that would replace the L pieces you have now. The hole is to access the balance bar adjustment. The green line can be the extra support bars that goes to a mounting point below, near the steering column. You could also make the lines more angular and the hole a triangle if you think it would looke better. It would probably fit the lines of the car better....
      Rich
      Greenwood, SC
      Yes, the bottom plate has 4 small bolts that run through my bracket into the tilton bracket. I did that to resist the rotational force that is created from the pivot on the balance bar. As it sits, there are four 5/16 bolts in the angle steel (2 per side) and four 1/4 bolts in the bottom plate.
      The main reason I built it like this was for the adjustability. It is more of just a mock up/jig because I can slide the Tilton assembly toward or away from the firewall.
      I think what I will do is just get my pedals remounted and buy the two MC's that I think I need and just see how it all actuates. Then try to build a rigid, final bracket.
      I don't think that the strap going down to the firewall is necessary. All of the weight of the bracket is supported by the 4 posts coming from the pedal assembly through the firewall.
      JC Scott
      Charlotte, NC
      I am changing my
      sizing on my masters one more time. Once you figure out what size you need drop me a pm. I have every size master that tilton makes that I have bought getting my brakes dialed in. I am now going for a 7/10 front, 3/4 rear. If that works for me, which I think it will, i will have 5/8,7/8 and a 1 inch that have a few miles on them.
      What brakes calipers will you be running on your car? What pads? Pedal ratio? I may be able to help you get close on the sizing.
