      Oct 2008
      Durham,NC
      Differential fill plug tap size?
      Well I had no choice in having to drill (etc) my fill plug out of my 1972 Chevelle rear differential and was wondering 3 questions from you guys. First question is does anyone know the tap size? Second question does anyone make a bigger fill plug in case I have to go that way (fingers crossed). Any help would be great been fighting a battle and want to finish this rear axel up finally.Third Where to get this tap from Napa,Lowes,Home Depot? I mean this is a decent size tap sure it might be little fun! Thanks in advance for any help!!! Brandon
      Loganville, GA
      You could add a fill plug to the differential cover instead. Just put it just above the fill level and you're good to go. Might be easier than drilling out the stock one, or at least a temporary fix. Just be sure to put it on the right side away from the ring gear.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Oct 2008
      Durham,NC
      already drilled it out now just need to tap and install new plug. put good idea Randy
