      Aug 2009
      transmission upgrade help
      Hi. I've upgraded the 305 in my 85 Monte Carlo SS to a 350 and have now blown out the 200r4 tranmission. Can i get some suggestions on a replacement transmission?
      Houston, Tx
      Get a T56. You won't regret it. I have a thread detailing the install in this forum and will finaliZe everything when I fully complete the install
      Sunny Florida on the Suncoast
      If you want an automatic the 200r4 can be built by many different shops to handle the load (remember GN run the 200R4). I would personally talk to California Transmission (the real Art Carr) he has more experience at making the 200 live in big HP cars.
      If you want a manual I would go with a TKO600 over the T56, the .50 overdrive and DEEP 1st gear is a waste, and the shifter location is tougher on the 6 speed. I have a TKO600 in my 68 Chevelle and love it. If you think a T56 is for you then look at the Magnum T56, much better gear ratios. Be prepared to have a tough time finding a clutch pedal, bellhousing, and mechanical clutch linkage for a G-body.
      Stay in it till you see God....then lift
      Where patience fails, force prevails
      "When you're born, you get a ticket to the freak show. When you're born in America, you get a front-row seat." G. Carlin
      Stapp's Ironical Paradox...... "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
