    Results 1 to 12 of 12
      Crown Point, Indiana
      valve cover really leaking
      I just installed new gaskets Felpro neo preme with steel inserts. And they are leaking like crazy from the rear bottom on both pass and drivers side. Is there any suggestions Small block chevyw/ cast alum valve covers.
      Southern California
      Got a breather hole in there?
      Check your breathers. Mine were leaking and the oil dripped down to the covers and made it look like it was the gasket. I also have the felpro metal inserts and no more leak after I replaced the breathers.
      Newbury Park, CA
      Make sure that both the head and cover surfaces cover the sealing bead on the gasket. The GM Fastburn head has a relief cut into the sealing surface that does not cover the sealing bead, hence big leaks.
      Rustburg, Virginia
      I agree, pay close attention to the sealing surfaces, something isn't right.
      Rural Retreat,VA
      Had same problem, Reseal valve cover, lil dab of silicone where the fastburn heads are cut, put a pcv valve on it No leaks...
      Thanks, I will try the dab of silicone.
      The heads are AFR's, I think I will also check
      the valve covers maybe a little warped.
      Checked the valve covers they do not seem to be warped. I thought that this breather cannister took the place of the PCV
      http://
      Winter Park, FL
      I had a leaking problem with some aluminum valve covers and discovered that the boss around the bolt hole was pretty large and was riding on the pushrod guide plate, keeping them from sealing. Just a thought.
      69 Firebird Convertible.
      www.stevegarrison.com click Firebird link at bottom of page
      Just bought a set of felpro cork with insert p# 1604. I will give these a try!
      Put the cork ones on and no oil leak.
      I am a happy camper!!
      Southern Indiana
      NEVER NEVER NEVER run a street car withouta PCV system or vacuum pump.
