    Results 1 to 1 of 1
      Houston, Tx
      LS1 T56 in a SBC - Install question
      Hi All,
      I have a quick question. I just finished installing my T56 and I just want to make sure everything is done properly.
      When I push the clutch all the way to the floor in first gear with the engine turned off i am able to move the car back and forth (just like it is neutral).
      Here is the question -
      When it is in first, engine off, clutch to the floor and I move the car back and forth you can barely hear the flywheel move against the clutch (i think)
      Is this okay? If I run the engine and drive through the gears will my hydraulics self adjust so that everything works perfectly?
      I am posting in the Transmission section too and will move the feedback from this thread into there.
      Chris
