Results 1 to 12 of 12
Thread: Can't remove tranny
08-22-2009 #1
Can't remove tranny
Decided it was time to replace the clutch in my Blazer except I can't get the tranny out. I've removed the driveshaft, cross member, shifter housing bolts, and have all the engine to trans bolts out except one. The last one is completely loose except I can't remove it because it's up against the trans tunnel.
Can anybody offer some suggestions? I need to get the clutch in by tomorrow night and I've already worked 6 hours and haven't made any real progress! Thanks.
Later, Doug
08-22-2009 #2Try tilting the assembly. If it's one of the upper bellhousing bolts try tipping the engine forward.
You could try using a prybar or something to dimple the firewall for clearance.
An extreme method would be to cut a hole in the firewall, but you should not have to do that.Jason Scheer
08-28-2009 #3
- Jan 2006
- Garwin, Iowa
- 241
loosen body mounts and put a 4x4 wood block between the frame and body.
08-28-2009 #4
