      May 2006
      hydraulic e-brake set up?
      Can I tee this into my rear brake line? I have LS1 brakes on all 4. I was reading you can and you can't. The other way to get it to work is to mount another set of calipers on the back which I really dont want to do.
      http://www.horsepowerfreaks.com/part...ydraulic/13420
      Canton, Oh
      From what I read on that website is you run it inline. If you tee it in then you would probably have to worry about pushing fluid back into the regular M/C.
      Later, Doug
      May 2006
      Is it possible for the fluid to back track and come out of the M/C? Anyone know for sure?
      Canton, Oh
      Quote Originally Posted by vannatta20 View Post
      Once the pad contacts the disk, the fluid is going to take the path of least resistance and head for the M/C rather than build pressure.
      Later, Doug
      Auburn, WA
      From what I understand, those don't lock into position. They're just used for momentary usage.
      Part of the point of a true E-brake is the application of brakes by a method other than hydraulics in case of failure.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      May 2006
      I am going to use it for drifting but it does have the option to lock in position as well. I do have a extra set of rear calipers so i just need to figure how to mount them.
      this isn't so much an "emergency" or "parking" brake, as much as it is a hand operated brake lever.
