    Results 1 to 19 of 19
      San Francisco
      EMERGENCY! No Start! Help!!
      I wanted to head over to the DMV so I got into my car and it wouldn't start! It started at first normally but it wouldn't get the engine going. I tried three times and then looked under the hood and noticed one of the ignition wires off the distributor! I don't know how that happened but I put it back on and it still won't start. It kind of turns the engine but then clicks a lot like it isn't catching the flywheel. Did I screw up the ignition timing or something? What can I do to fix this?
      I have a 67 Camaro with a 70 400 sbc. ignition was modified to magnetic pickup with a blaster coil.
      1967 Chevrolet Camaro 350/350
      1962 Chevrolet Chevy II 400 194/PG
      Mar 2002
      Redwood City, CA
      battery. You need a jump start.
      Allen Ortega
      San Francisco
      battery
      the fan and lights work, but could it still be the battery?
      Nov 2002
      Reading PA
      battery doesn't have enough "umph" to start the car...like zbugger said, you need a jump.
      Todd
      67 RS/SS Camaro (FOR SALE), 73 Camaro, 15 Jeep Wrangler Unlimited Rubicon
      http://www.fquick.com/qwik1320
      San Francisco
      i got a jump, and i got it going finally but it won't hold a charge! it runs only with the headlights off.. so it must be the battery right? but it was running great the day prior! and it's only half a year old! it's a red top optima starter battery. the car however was taken apart for 3-4 months and did not run. but still, the battery worked fine right after i started it, i can't imagine why it would die now. any thoughts?
      Nov 2004
      Sometimes a battery needs a nice slow charge to refresh it. I hope there is some science behind that statement, but lets just say that on batteries that have had issues, I'll put them on the lowest amp setting on my charger and let them sit for a day - poof, they suddenly act normal again.
      Ian
      Nov 2002
      Reading PA
      Is you alternator charging/hooked up? Check to make sure you don't have other wires off or loose. The battery is there to get the car started...once it's running your alternator should supply the power you need. If the battery has been dead for awhile it may take some time to fully charge (don't charge it overnight unattended though, safety first!)
      Todd
      San Francisco
      Wires
      well when i jumped the car, the voltmeter read at about 12 amps and then as i kept it in idle it slowly just went lower and lower. it didn't look like the alternator was charging it at all. i even drove it around for a bit with the lights off and it couldn't charge the battery even a little. the voltmeter just dropped to red. then i turned the lights on for a second and the car almost died.
      do you still think the battery can be recharged slowly and work?
      also it wouldn't be the wiring right? if i jump from the battery and it starts that means the cables are good right?
      Macon, Ga.
      Sounds like your battery is dead because of the alternator problem. Just charge the battery and it will be fine. However sounds like it is new alternator time. One quick check to see if the alternator is charging without a gauge is to hold a screwdriver flat about 1/4" from the front of the pulley with the engine running. If it is charging, it will create a magnetic field and will pull the tool to it. This must be done very carefully or you will launch the screw driver to who knows where but it will work every time. If you have not converted the car to a alternator with a built in regulator, then be sure to check the regulator too. Most all parts houses have test benches now and will check it for free if you take it to them, but you might as well take money with you since I am sure that is the problem is unless it just has a loose connection somewhere.
      Bill
      Trailers are for BOATS!
      Miami, Florida
      Holy mackerel...
      I don't think I'd want to try the magnetic screwdriver test!!
      I'm pretty sure Autozone will test your alternator for free. A voltmeter would work as well wouldn't it?
      Kevin.
      69 Firebird "Eternity"
      If you use a voltmeter it will show voltage. The voltage at the battery with the car running should be between 13.6 and 14.2 volts. This is a quick check however it will not determine the amperage the alternator is putting out. You could use a clamp on ampmeter on either the negative or positive battery cable with the arrow on the clamp facing the direction of current flow. Current flows negative to positive. If you are unsure of the direction of the clamp just put it on one way and it will either read - or + amperage. If it reads negative turn the clamp around. The other way is simply drive the car to your local autozone and they will check the alternator for you for free. Good luck.
      Aug 2001
      Keep the screwdriver away from the front like that nutcase told you. With the car running put the screwdriver on the back center of the alt. There is a little plug that covers the rear bearing. If it is charging, that plug will be magnatized. If it is not, then your alt is not working. Check wires before getting another one.
      Mar 2002
      Redwood City, CA
      Thank you Charlie. Yes, start by checking the wiring. Make sure it is all hooked up and correct. Then you can do the screw driver test, but I'd really recommend using the voltmeter to see just how dead it is. Odds are you'll see just below battery voltage at the alternator's bat teminal.
      Damnit Bill, you're gonna get someone killed with that work........ Hmmm.... never mind. Comment being kept to myself.
      Allen Ortega
      San Francisco
      Sorry, one more question! I was wondering if I do find that it is the alternator, and I install a new one, will I be able to jump start the battery and charge it from the new alternator? I don't have a battery charger on hand. If it's unsafe do you guys know anyone in the Santa Cruz area who can charge it for me? Thanks!
      Clarendon Hills IL.
      Just about any auto repair shop will charge your battery for you for a small fee.
      Nov 2000
      O-town
      Thats not a cover on the rear, thats the actual bearing, stay away from AutoZone or other ones like that. I have a one wire alt, I thought it wasn't charging, long story short, the chain places couldn't get the alt to spin fastenough to getit to kick into charge cycle, has to go over 1200 rpm, 2 Cents
      Mar 2002
      Redwood City, CA
      Roaring Eagle, I'm accross the mountain and up the peninsula from you. Wanna try and work something out? Otherwise, yes, you can charge the battery with the new alternator. One thing I do to charge a battery after a jump start is to leave the two cars hooked up for a bit. Leave both of them running. I'd keep the idle around 1000 to 1500 rpms for both engines. This will lessen the instant load on the alternator in the car with the bad battery.
      Allen Ortega
      Macon, Ga.
      Quote Originally Posted by Charley Lillard
      I have been looking to open a shop here in East Tn. Let me know if I can do anything for you. We only have screwdrivers and pliers here.
      I have been gone all day-April fools fool
      Bill
      San Francisco
      Andy's Auto Supply
      I replaced the alternator and now I'm back to normal, up and running! I went to Andy's Auto Supply in SC, CA and they charged my battery for me and helped me swap the pulley and fan. Thanks for all the help guys! I need to get a new wiring harness ASAP though, anyone got one lying around they wanna get rid of?? Thanks again!
