Results 1 to 20 of 35
Thread: bellhousing alignment
08-17-2009 #1
Alright, so I just spent the better part of the night doing my bellhousing alignment with a dial indicator and magnetic base. Let's just say that it was a pain in the butt also. I had problems getting a reading that could be reconfirmed with each pass. I took a reading at every 45 degrees for four passes and each pass came up with something different almost with some reading the same. I was taking the reading from the outer exterior lip and I think since it has breaks in it it made the dial change. I didn't take it on the inner lip since that's where it's welded and the weld is not a continuously flat surface. I tried taking it from the inside of the bellhousing thinking it was a concentric circle but apparently the powdercoating has different densities on the interior also.
Here's a pic:
You can see the dial indicator also and the lip it is riding on. Some of the times it hit one of the breaks in the lip and then tried to pick up afterwards it seemed to "jump the track". I think this was throwing off my readings also and screwing with the indicator.
Anyway, here's the readings:
0 degree reading: 1st: -.010 2nd:.000 3rd: -.002 4th: -.002
45 degree reading: 1st: -.003 2nd: .007 3rd: .005 4th: .005
90 degree reading: 1st: .000 2nd: .010 3rd: .013 4th: .010
135 degree reading: 1st: .011 2nd: .012 3rd: .010 4th: .012
180 degree reading: 1st: -.006 2nd: .005 3rd: .003 4th: .003
225 degree reading: 1st: -.011 2nd: -.001 3rd: -.001 4th: -.003
270 degree reading: 1st: -.014 2nd: -.006 3rd: -.007 4th: -.009
315 degree reading: 1st: -.017 2nd: -.008 3rd: -.006 4th: -.009
As you can see my last two readings seemed to be a little more accurate. My baseline "zero" reading was actually setup at 90 degrees hence the first reading of zero there. It was just easier to setup the dial indicator at that position for me.
So, how should I go figuring up my information? Should I average the last two sets of numbers and get my low and high numbers to figure out what type of offset dowels to use?
Any suggestions appreciated.
2001 Camaro Z28 (DD)
LS3 525hp GM crate engine, built 4L60e
1974 Camaro Z28 Type LT
Solid roller 355 sbc with T-56
08-18-2009 #2
Starting The Transformation
- Dec 2008
- Knoxville, TN
- 363
Hey kyphur,
good work on documenting your dial in. you are on the right track on your assumptions:
- powder coating is messing up your reading
- indicator is "jumping track" and throwing your numbers off
- numbers are not repeating like they should
I've marked up your pic with some colored arrows and a legend on what changes to make.
Also, watch the bellhousing dial in how-to video. This Hi-LOW 2point method is easier.
If you still get erratic readings, then a couple of factors could be going on:
- your indicator is not rock solid. it may be moving at the joints or the base. (you won't be able to see it move to create the error in readings)
- the bellhousing bore may not be round
- there may be small burrs or dents in the bellhousing bore
As to the dowel pins, I'd recommend you pick up some .007inch but it's not clear if you will need them yet.
ShafiLast edited by KEISLER; 08-18-2009 at 04:58 AM.
08-18-2009 #3In the video they only have two reference points (the -1 and the +6). Was this taken at the "maximums" of the values or just two reference points randomly chosen? If I do my two maximums (.012 and -.009) in what I believe is my most accurate reading and which are also 180 degrees apart from each other that gives me a measurement of .003 divided by half which is .0015 right? That's if I did the measurement correctly right?
08-18-2009 #4O.K. Just rewatched the video. My .003 that I stated up above is run out and then when you divide it by half you're getting your offset numbers. So if my .003 run out is correct then I would be safe with this install. Then if I wanted to nail it 100% I would use offset dowels for .0015 in the direction of my positive number (.012) to clear it up and center it.
08-18-2009 #5
- Dec 2008
- Knoxville, TN
- 363
Bellhousing Dial In
OK, good question. Let me explain about how runout works with regards to the bell and the crank.
First, there is a difference between the true center of the crankshaft, and the true center of the bellhousing. The straight line (radial direct) amount of difference, in inches, is OFFSET. The Offset multiplied by 2 will be the RUNOUT.
You can break down the Offset as a vector in X and Y axis, then make the corrections in the equal, but opposite directions, to get the true centers in line with each other. That is one way to go about dialing in the bell, but it requires you to take the square root of the sum of the square of each x and y component to get the radial distance, but this is somewhat cumbersome.
The other method is the way I explain in the video - the Min Max method. Using the Min Max method, you don't have to fuss with the x/y-component math. The Max runout point, should be 180 degrees opposite the Min runout point. If you think about it, the Max runout point is where the bellhousing bore is farthest away from the indicator, and the min point is where the bore is the closest to the indicator. Once you find out the amount of the two value, then you have determined how much offset you have (the difference divided by 2), and you can select the right dowel pin.
It makes the math a little easier to understand if you find the Min point, and set your indicator dial to zero. Let's say you do this, and you find the runout as follows:
MIN = zero'd out at 18 degrees
MAX = .012 inch at 198 degrees
Then this says you have 12thou runout, which is 6 thou (.006) offset, so you need a 7 thou (.007) offset dowel pin set to correct for it. When you install the offset pins at 198-180=18 degrees direction, you will create a resultant offset of .001 in the direction of 18 degrees, which is .002 runout = within spec of .005 runout = EXCELLENT.
What can complicate the measurement and correction of runout is when the bellhousing bore is not a circle, but an oval, which is usually caused by incorrect machining setup at the supplier. Also, burrs, dents, paint, etc creates problems, so be sure to remove this using a file or burr removal tool. When we do an install, we mask off the back face and the bore before doing any painting. Same goes for powder coating.
Hope this helps!Last edited by KEISLER; 08-18-2009 at 09:29 AM.
08-18-2009 #6
- Dec 2008
- Knoxville, TN
- 363
08-18-2009 #7Yes, this makes tons of sense and simplifies the process a lot. Thank you for all your help!
08-18-2009 #8
