    Results 1 to 20 of 37
    Thread: Project "C"
      Tennessee
      Project "C"
      All the kewl project names are taken...lol This is the other truck were doing here at R.A.W. RODS 70 C10 big block truck. The truck started out as a long bed and now is a short bed. My customer already had a short frame to go under it, a new short bed was orders with the wood floor. The truck was bought new by his grandfather and was passed to his dad and them him. He's going with the stock colors orange with a black upper cab and lowering it 4" all around with 18" wheels. Here are the picture as it has come in to the shop.
      Tennessee
      The rockers are pretty bad so I pulled them off to sandblast and found well more rust.
      As you can tell the more I blast the more rust that pops up. Some pretty bad rust were the A/C was mounted.
      Jun 2009
      OHIO
      i'm going to be keeping my eye on this one. This is going to be my next project when done with the 68 again,lol...nice start
      68 Camaro
      Tennessee
      Today I got some of the rust cut out of the fire wall and made a few patch panels.
      Here's the patch I made for the firewall
      Filled the hole in the cab for the gas neck. It will be moved under the bed.
      Heres what was behind the outside cab corners.
      Test fitting the new panels.
      May 2009
      Centennial, CO
      I will be watching this...my 72 long bed is next after my 63 Chevy II
      Tennessee
      Got the cab corners on and started welding the new panels in place.
      Just checking the fit for now.
      Also had to replace part of the supports under the cab.
      After getting both sides done I blasted the bottom.
      Next I'll start Installing the Rocker's
      St Louis, MO
      Love it. I love these trucks. This will be my next build after my current one....hopefully.
      Apr 2004
      OKC, OK
      Been there done all that on my 69 Blazer. I hope to get back on it after SEMA
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Nice fab work on the firewall . its a nice project.
      Jun 2009
      OHIO
      so what kind of blaster are you using?
      68 Camaro
      Tennessee
      Quote Originally Posted by HILLBILLY68 View Post
      Its a EMPIRE Presser Blaster. Works great if you have the Air Compresser to support it. I can run this thing for 1 hr with a 100 pound bag of Black Beauty Sand. I have one of there big cabinets too and love it.
      May 2000
      Quote Originally Posted by r.a.w.rods View Post
      So that type of sand is okay on large body panels? What pressure do you run to it?
      Will it take undercoating off?
      Tennessee
      Quote Originally Posted by MarkM66 View Post
      Some undercoatings are a pain to get off. Most of it on this truck came off pretty good but there was a lot I had to strip off by hand then blast. They make stuff to spray on undercoating to get it off but I like heat and a sharp blade or you can use a wire wheel. As for how much pressure, I go around 110 psi for frames and things that I know will not warp, but for fenders cab's I turn the presser down and dont blast on one panel too long. If you do your heading for trouble. After blasting we still go over the metal with 80g paper and then DP90. I really didnt want to spend the money on one but now Im glad I did. Now I dont have to hurt my fingers in the hard to reach places. I asked the guy about the sand and said it was fine to use and is safer for your lungs( STILL WERE A FILLTERD MASK). DO NOT USE PLAY SAND like at lowes I know people do but dont. When you go into a place that sells this kind of stuff they will have all kinds of sands for you to look at for what your doing. I hope this helps you out.
      Tennessee
      Well I have the rockers on for good now. I used plug welds just like stock, really makes a clean look when primed.
      Primed In DP90.
      Jun 2009
      OHIO
      looking good
      68 Camaro
      Iceland
      Country Flag: Iceland
      iceland
      May 2009
      Centennial, CO
      Don't know what your plan is for the gas door but, I worked at a shop where we used a gas door and arm (from a 90s something) and cut it down to bolt behind the left bed side marker ligh. Put a blazer tank under the bed and used a early model blazer inner tube cover in the bed to "hide"0 the tubes and such. wish I had pics it work out pretty slick. We also used one of those gas caps you don't have to take off, it has the little door built in. Anyway just a thought and rambling. You are haulin on this truck. Are you taking a break from the ford?
      Tennessee
      Quote Originally Posted by Draginutz View Post
      The Ford is waiting for the A/C to come in, so parts are getting block sanded. My customer is using the blazer tank and wanted to put the gas door in the tail light but went with a floor mount cap in the bed. Im using the gas cap that has the trap door on the Ford.
      Thanks guys I should have some more pictures tomorrow.
      Dunwoody, GA
      Nice work. One day I hope to weld that nicely. Keep it up.
      Trey
      ~ Jon Hammond
