    Results 1 to 11 of 11
      Fullerton, CA.
      5.3 conversion wiring Confusion/solution
      I have a 2003 5.3 engine only so I have to supply my own harness and ECM. I can get a deal from Painless, and get a reman ECM. Or go through Tech Rods and get a Reman ECM and have it Re-Flash. My rep from painless says that they will re-flash my ECM to my specs for free.
      Or Get a donor harness (if so from what car) and mod it and get a Reman ECM. Lots of options in need of a little guidance. I will be using a LS-1/6 Intake and a 200-4R trans and Camaro based Kwik-perf Pulley system. HELP
      Mike Martin
      Heavy Chevy 2.0: 71 Heavy Chevy, Unisteer,SC&C, GW,Eibach,Bilstein,Helwig,Showwheels-Streeters, Carb'd LS-327 W-200-4R
      LS-327 powered, Atomic EFI on the way
      Midwest
      Are you near a decent chassis tune shop? I'd get the stock ECM and have then tune / flash the box with an edit program so you know it's right.
      Kevin Oeste
      V8 Speed and Resto Shop
      V8TV
      Muscle Car Of The Week
      V8 Radio Podcast
      All about us:
      https://www.v8speedshop.com
      Fullerton, CA.
      I have a decent shop nearby and I will more than likely take it to them to dial it in. I just checked the so-called deal on painless and I guess I'll be looking elsewhere. I assume if I get a Camaro Harness (for example) and remove all the un-needed stuff myself then get an ECM for the same year then I could have the ECM flashed by my local shop to get it running and then bring it in for a final chassis tune. Does that sound about right.
      Mike Martin
      Speartech.com
      Wait4me performance
      two more options for ya.
      Nathan Shaw
      71 Nova, 1000+whp 5.3, 8 second autoXer.
      Central Florida
      Apr 2004
      OKC, OK
      Forget painless, go to speartech, not sure tech rods is even around anymore
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Yep, Tech Rods appears to still be on Ebay. $400.00 for harness.
      Everett, WA
      Speartech x4. John is great with supporting his harness if you have installation problems.
      PCMforless.com for the computer.
      The few, the proud, the crazy... the LT1 owners.
      Jun 2005
      Lynnwood Wa.
      Oliver Shultz
      It's OK to giggle and snicker. don't laugh and point
      Newbury Park, CA
      If you are on a budget you may want to consider an ECM and harness from a truck. The harness is usually long enough to mount the ECM where you wish, and gutting it is no harder than the F-body harness.
      Fullerton, CA.
      Thanks Carl I may ask you for some advice/input later. I think that will be the way I go. With the truck harness/ECM and mod it. If I run the LS1/6 will I have to change the injector plugs? I don't think the trunk injectors will work with the LS1/6 fuel rails. Or has anyone made the truck intake look good(Just kidding). After this weekend I'll have 2 5.3's I'm picking up another one for a 20 pack of Coors light. This one is a clean runner top to bottom.
      Mike Martin
