    Results 1 to 15 of 15
      Aug 2009
      Headers on engine install
      I have a set of summit full length headers on my 400 going in my 78 T/A. I'm trying to drop it in but it seems to be hung up. Is there any trick to getting this to drop in. I really don't want to take the headers off being its a PITA to put them on. i've got the motor sitting at a pretty steep angle, maybe i need more? HELP!
      78 Trans Am 6.6L,TH350, 3.08 posi, work in progress.
      Asheboro NC
      well,,heres a dew thought. put the header in the engine bay and strap them to something to hold them in place then putin the engine, or try puttin the headers in from the botom after the engine is in?
      Sunny Florida on the Suncoast
      Quote Originally Posted by slownova73 View Post
      This is how I would do it. Pontiac's (along with other GM off brands) can be such a PITA when installing headers.
      Stay in it till you see God....then lift
      Where patience fails, force prevails
      "When you're born, you get a ticket to the freak show. When you're born in America, you get a front-row seat." G. Carlin
      Stapp's Ironical Paradox...... "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
      Jul 2009
      Merchantville, NJ
      As a Pontiac guy running HUGE headers, slownova73 is doing exactly what I would do. Otherwise, you might be fighting for days on end.... Pontiwrecks suck for headers, and I am referring to the 350-455 models.
      1968 GTO 467 ported Pontiwreck, 9", 5-Speed
      2000 Viper GTS, 10Lb SC, Roller Cam, Fully Ported
      2008 Viper SRT-10 Coupe, Stock, FOR SALE
      2008 Grand Cherokee, 3" OME Lift, armor/winched
      2006 Votes thanks to Acorn
      Jun 2009
      Southwest Florida
      I'd just unbolt them from the engine and deal with the hassle if it won't fit installed. Maybe try partially unbolting them so they can hang at an angle then tighten them back up when it's in. Installing headers on my olds 350 (72 cutlass) with the engine in place was a similar headache. They "almost" fit but hit a few things, tried hammering on the tubes a bit for clearance but no go. Even pulled the dipstick off since it was getting in the way. Ended up unbolting the trans and engine mounts and jacking the whole assembly up a few inches to get clearance. Then ran into issues tightening everything back down because the motor mounts were too worn out, new mounts got the engine noticably higher and we might have been able to do the install without jacking the engine up.
      -- Dan
      just because all the car magazines show an engine hanging over an engine bay with the headers installed doesn't mean they can be installed like that. i think only the NASCAR guys can do it that way.
      i'd probably do as has been suggested and lay the headers in the engine bay and drop the motor in between them. a couple of helpers would be nice to have to hold the headers up and help guide the motor in..
      Jul 2009
      Merchantville, NJ
      Try doing slip fit headers on a Viper, it is NO FUN, but honestly my GTO is the worst car to ever put headers on. Between the scattershield, AC and huge Hooker Super Comps (maybe 1 7/8" if I remember), it is a TOTAL bear....
      Quote Originally Posted by BAD68GTO View Post
      the unknown brand headers of unknown vintage that i used in my V8 Vega weren't very much fun, and neither were the Flowtech long tubes in a friend's 89 5.0 Mustang.
      both headers on both cars were 3 piece contraptions with slip joints in about the worst places they could think to put them.
      in both cases, they got easier to work with and around after repeated remove/install sequences.
      So Cal
      If you somehow manage to get that engine installed with both headers bolted to it you'll be the first guy ever to do it on one of those cars.
      At least one will have to come off, and I wouldn't recommend trying it with one still on it.
      Lay them both in the engine compartment (use some wire to hold them in place) and drop the engine down onto them.
      It's never a bad idea to bolt them both on to check fit, but putting the engine in with them already bolted on isn't going to work.
      Good luck.
      Bart F.
      '64 Tempest - LS3/4L70E - Grandma's Poor-Touring car
      '64 GTO - 455 HO/TH400 - Ex-bracket racer, street bruiser
      '02 WS6 convert - LS1/4L60E - Pure stock, pure pleasure
      Aug 2009
      I've already taken them off....gotta wait til the weekend to give another try at the install. first i gotta get a cross threaded bolt out. UGH! Never ending battle! BTW, has anyone tried the Percy's header gaskets and bolts?
      Asheboro NC
      Quote Originally Posted by tnbandit View Post
      i had the percys aluminum crush gaskets and bolts on my old 350, i never had one problem!
      Aug 2009
      yeah i have the crush gaskets.....is it normap for them to look like the flange is not seated all the way against the head? Are they that thick?
      Sep 2009
      Charleston, SC
      I have a 78 Firebird with a SBC and long tube hedders and I've had this car apart and back together a bunch. The only way is to do it is with the engine already installed. Jack the car up high in the air (secured with good stands) and come in from the bottom. My recollection on Pontiac-powered cars is that it helps to remove the accessory brackets on the front as well so that you can slide the hedder forward as you come up from the bottom and then pull it back towards the firewall.
      89 Supercharged Saleen 352 rwhp, 93 Mustang LX 347 stroker 420 rwhp daily driver, 78 Firebird, 69 Opel Kadett Rallye ex-SCCA track car..."everyone needs to own a 4-bbl 4 cylinder once"
      Jul 2008
      High in the air is the key!!!!
      Sep 2009
      Charleston, SC
      I forgot to mention that it also sometimes helps having the engine hanging from a hoist with the car on jacks. that way you can adjust the car, engine, and hedders a little at a time. hope this helps.
