      Jun 2009
      Decatur, AL
      t-56 shifting question
      Went with a friend to check out a t-56 transmission today. It was unhooked and out of the car but as he shifted through the gears for a quick little test it would not go into reverse. Is this normal with it out of the car? I didn't think it was but I wasn't sure.
      2001 Camaro Z28 (DD)
      LS3 525hp GM crate engine, built 4L60e
      1974 Camaro Z28 Type LT
      Solid roller 355 sbc with T-56
      Eastern Virginia
      There is a reverse lockout solenoid that keeps it from going into reverse unless energized. Once energized it will go in easily. You can muscle it & over ride the solenoid though. In a factory setup the PCM energizes this solenoid if going less than 5mph, that way you don't accidently hit R when going from 4th to 5th.
      Scot
      86 Monte SS
      Jun 2009
      Decatur, AL
      O.K. Cool thanks. I was pretty sure the transmission was in working order since I saw the car with it in it driving around about a week or so ago and knew the guy. I didn't think he'd pull one over on us but we went out there by ourselves and he left his shop open for us while he was out.
