      Jackson, MI
      Notchy clutch pedal
      Last summer I swapped out a Saginaw 3-speed for a TKO600RR 5-speed in my '67 camaro. Best thing I could have done. My small block isn't anything special so I just used a standard Ram clutch and pressure plate. Over the last couple of weeks I started to notice that my clutch pedal is starting to feel kind of notchy. It's really kind of anoying when I try to take off nice and easy from a stop light. I figured that the stock linkage was the problem so I lubed the Z-bar and squirted the other pivot points with WD-40. I checked it without the car running and it seems really smooth but as soon as I started it up, the notchyness came back. Is the pressure plate going bad? It's only a year old and it probably only has a few thousand miles on it. It still seems to engage and disengage ok. What do you guys think?
      Jason
      67' RS Camaro
      71’ Corvette
      85’ IROC
      Feb 2006
      Columbus, GA
      I had the same problem with mine. I went through all of thre same things you did, i.e. lubeing cross shaft/linkage etc....still the same. I'm attributing it to the CenterForce pressure palte. The car is in the air right now...changing the pressure plate and disc...
      1970 SS Camaro, 502 RamJet, TKO600 Tremec, 3.91 Moser 12 bolt/Detroit Tru-Trac, C5/Z06 Brakes.
