    Page 36 of 101 FirstFirst ... 26 31 32 33 34 35 36 37 38 39 40 41 46 86 ... LastLast
    Results 701 to 720 of 2014
    1. #701
      san diego
      Here are the TCI double adjustable shocks with the afco springs.
      The look nice in the box, hopefully they will look nice on the car.
      I hope everyone had a great christmas. My family did! my wife cooked christmas dinner for us, her first ever and it was amazazing.
      I got a bunch of tools for the new garage.
    2. #702
      alpine ca
      looks great bryce cograts on her christmas dinner
      john
      BUILD LINK
    3. #703
      Jul 2010
      Amazing Falcon
      Bryce, I've got a '63 falcon that I'm working on right now. I was looking up ideas on how to upgrade the suspension from the 47 year old set-up that it came with, when I ran across your post. Right now I've got a TKO 500 waiting to go in and, some extra aluminum laying around that I'm able to make some other modifications with for now. I noticed that you were in San Diego, and was wondering if it would be alright to come by and see the set-up that you have. It doesn't look like I have near the engineering skills that you have, but it would still be a great help. I'll put some pictures up probably tomorrow.
      Incredible job, and thanks for sharing this with everyone.
    4. #704
      May 2008
      Austin, Tx.
      Hey Bryce,
      VERY nice looking set of shocks/springs! You should be able to dial in the handling with them! If they perform as well as they look you should be doing great!
      Keep up the GREAT job! It's getting closer and closer...
      Ray
    5. #705
      san diego
      Quote Originally Posted by 454bug View Post
      Hey Bryce,
      Thanks Ray,
      They should be better than the afcos I have in front. These are a monotube double adjustable and nitrogen charged.
    6. #706
      san diego
      Quote Originally Posted by elgringo View Post
      Thanks Gringo,
      Post up some build pictures of your car. I will let you now the next time the car goes out to a local show or an SCCA event.
    7. #707
      san diego
      Spent some time making brackets today. These are the chassis side of the upper link. They have an arced slot and will be welded to the frame cradle. Not too bad for a bandswaw, drill press and an array of tools for the die grinder.
    8. #708
      TN
      Quote Originally Posted by Bryce View Post
      Spent some time making brackets today. These are the chassis side of the upper link. They have an arced slot and will be welded to the frame cradle. Not too bad for a bandsaw, drill press and an array of tools for the die grinder.
      You should have asked me, I could have cut them on a mill... made them pretty! haha!
      Benjamin
      Twin Dusters
    9. #709
      san diego
      Here is a quick update of some progress.
      Third link bracket tack welded onto the frame cradle.
    10. #710
      san diego
      I have one more thing to figure out before I can remove the entire rear suspension and final weld everything. I have been really slow the last few weeks. Too many distractions.
      Also, I have been planning a redesign of the front valance. Also I am planning on building a rear valance and still contemplating a wide body stretch.
    11. #711
      Birmingham, AL
      Sounds like a no brainer, but drive it some first and enjoy the fruits of your labor.
      Stephen
    12. #712
      Apr 2007
      Surprise, Az
      Didn't read everything you posted but why not just make a bracket with a bunch of slots in it much like the one on the top of your diff? I'm just assuming from all the pivoting motions of your rear end I would think it would come loose...Just curious
      1970 NOVA..Ls2/Tko..Speedtech/Chicayne, Alston Glink
      Chuck D.
    13. #713
      san diego
      Quote Originally Posted by srh3trinity View Post
      Yes, this will be down the road. I want to make it to goodguys and drive it over the summer. The some of the bigger projects will be started.
    14. #714
      san diego
      Quote Originally Posted by strtlegal View Post
      The slot is an arc centered around the rear connection of the UCA. The loads are always perpendicular to the slot, therefore there is no force to make the control arm move in the slot when the bolt is tight.
      Also the clamping force of the fastener would be enough to keep it from moving.
    15. #715
      SF Bay Area
      I'm no suspension expert, but won't that bracket for the upper link see some serious loads from the rearend? How thick are those pieces? Maybe it's just the angle of the photo, but it appears mighty thin.
      chunger
      '68 Ranchero 500
      '70 Cougar XR-7 Convertible
      '98 Mustang GT Convertible
    16. #716
      san diego
      Quote Originally Posted by chunger View Post
      Those brackets are 1/8" and they will be boxed in on the bottom and front side.
      They will see some high loads the max they will see is 4000lbs. That would be at the drag strip with slicks launching a 5000rpm and not spinning the tires. But 4000lbs is really not that much. A high quality 1/4 diameter fastener can take that load in single shear.
      Plus as an engineer, I like to do calculations. So I try make sure nothing I build is too heavy. If I can make every piece lighter then the car tends to be lighter.
    17. #717
      san diego
      I weighed all the old suspension yesterday, leafs springs with slapper bars and all the hardware, 83lbs.
      The new stuff is 55lbs without the brackets on the rearend. So i might end up a little lighter. WooHoo!
    18. #718
      TN
      Sounds good! I can't wait to see it finished!
      Benjamin
      Twin Dusters
    19. #719
      TN
      Oh! By the way. I found my measurements.
      Benjamin
      Twin Dusters
    20. #720
      Dec 2010
      Out in El Paso, TX
      nice work bro. Love the falcons
