Results 1 to 9 of 9
Thread: Cold Air Intake & Rain ???
I've been thinking about hooking up some type of cold air intake setup on my Cutlass, either under the bumper or in the hi-beam headlights. This will be a daily driver. I've often wondered what a person does if they get caught out in the rain.
Would it just be better to leave it off a driver?
I'd like some thoughts and ideas.
Doug Gulley
08-09-2009 #2I'm not sure how to do it, exactly, but if you use the proper bends you don't have to worry.
THe proper bend will be sharp enough to "throw" any water to the side of the tube and out of the air's path.
You need to make sure water can't collect in the tube.Jason Scheer
08-09-2009 #3Jason, you must be on the right track as I was talking to a guy at work about this today and that's what he said, too. I need to make sure I get this right, I'm running TPI with a MAF (the thin wire type from the 89 f-body) and I DON'T want moisture hitting that!
Thanks for the input Jason.
Any other ideas? I know more of you are running Cold Air Intakes. Don't tell me they never see the rain guys!Doug Gulley
08-09-2009 #4
