    Results 1 to 1 of 1
      Georgia
      Mark VIII fan rubbing
      Last weekend I took my 68 out on the first cruise after installing my new aluminum radiator. I noticed when things heated up, causing the DCC system to ramp up the fan speed, I heard a type of rattling noise.
      I emailed Brian Baskin at DC Controls and he explained that the Mark VIII fan will flex toward the radiator about .300 at full speed.
      My Mark VIII fan assembly is mounted directly flush against my raditor in order to pull as much air as possible through the plastic shroud. I did not want it to stand off as any gaps would allow air to slip in behind the radiator instead of going through the front.
      Anyone else have this rubbing issue at full speeds with their Mark VIII fan?
      Another issue is that the DCC temp probe fell out of the fins at one point, which caused things to really heat up quick. It was easy to replace inbetween another pair of fins, but I also wondered if anyone had a way of securing this probe from falling out again. My new radiator has a tighter fin spacing than others that I've previously owned, so much so that one of those radiator zip ties cannot fit through the fins.
      Marty
      1968 Camaro - World Products 427 SBC, TKO600, 8.5" 10 bolt, Touring Classics brake kit, DSE springs, Gulstrand mod, Koni shocks, AAW classic update harness, Vintage Air
