    Results 1 to 12 of 12
      little falls minnesota
      teflon heim joints
      teflon heim joints and spherical bearings are designed for
      'lube free' operation.
      if a person wanted that extra insurance for those high buck ends
      what grease would be safe to use?
      thanks, doug
      Jun 2002
      Benicia, CA
      Lube
      I used Red Line wheel bearing grease on my Herb Adams sway bar spherical rod ends with great results so far. There may be a specific grease so hopefully someone with that knowledge will chime in.
      Jeff
      1971 RS Camaro: PAINKILLER
      Central CA USA
      The trick would be to keep dirt out of the joint or the grease will collect it. There are circle track seals for them.
      Jun 2002
      Benicia, CA
      Good idea!
      Quote Originally Posted by David Pozzi
      I will look for those when I get my front end finished up!
      Jeff
      connecticut
      the reason they have teflon liners is so you don't have to lube them . teflon is self lubricating .plus the liner does a good job sealing out the dirt. just try to keep them clean and if you have to do something just a little wd-40 works great.
      Jun 2002
      Benicia, CA
      I think the teflon wears at a faster rate?
      I recall reading somewhere that the teflon one's require more frequent replacement, but I can't remember where I read that... Some may be rebuildable???
      Jeff
      Aug 2002
      Sweden
      Country Flag: Sweden
      Available from speedwaymotors, ridiculously cheap!
      connecticut
      Quote Originally Posted by Ripper
      i woulnd't use teflon rod-ends they are junk. but rather use teflon lined rod ends theese are the best quality r-ends you can buy .we use them if all our race cars .a standard 3/4 by 3/4 c-moly r-end runs about $35.00 not like the cheepo's that use the teflon as a bearing race.instead of just a liner.
      Aug 2002
      Sweden
      Quote Originally Posted by quadfather
      I meant the seals.. They are ridiculously cheap... I get it that it's not a good idea to use cheapest rod end available.
      Columbus, Ohio
      We sell FK rod ends, used by anybody in racing, drag, road, etc. The quadfather is right, we sell the super heavy duty 3-piece with a ptfe liner to all sorts of race shops in town. $35.00 is about right for 1 of these 3/4 x 3/4 ends. We never replace them because they have failed. The static load on the 3/4 x 3/4 is 28,090 lbs!
      Darren
      heim joints
      these are the style of rod ends i am using on the front a-arms i have
      on my chassis. i am also using 1" ID sperical bearing with S.S. housings
      for my rear lower control arms.
      i havent been able to find a source for 1" bore seals.
      i found some grease intended for 10,000 rpm moulders at work, but it runs around $85 a tube.
      doug
      Columbus, Ohio
      Pics? got part numbers? I will call FK on monday and see If I can come up with seals for ya.
      Darren
