    Results 1 to 14 of 14
    Thread: Engine builders
      Jun 2009
      Engine builders
      I was hoping to compile of list of engine builders people here have used and been happy with.
      I would like to have an LS3 engine built that makes between 550-600 HP. Would really like a 427 but that is not a have to have, but more of a want. What engine builders have you used and how was the experience?
      Aug 2003
      Wegner Motor Sports has a new "Bull Run" Crate Engine package they are doing for us.
      It is a 415CI 601HP motor that is a duplicate of the motor in the Bull Run Racer we just finished. We just did the 3000 mile torture test known as Bull Run and did everything from 3hour Manhatten traffic, to Taladega laps near 140MPH, some drag racing, 98 degree 5PM Atlanta traffic, you name it. Flawless performance. It is a bad puppy and has Wegners Nascar technoligy inside.
      The dyno sheet is a work of art. Pricing is awesome at $14,800 INCLUDING their trick front drive accesories.
      Ted's 68 Chevelle Bull Run Racer
      Check out the peak power at 6600RPM and then check the power at 600RPM and 7200RPM. Nascar head porting at work right there.
      The Bull Run PAckage includes the $2200 front drive set up
      The Wegner boys built my 620 hp 427.
      They really really know what they are doing. Carl Wegner is the force behind the NASCAR LS-based spec engine, used in many of the junior circuits, and he's trying to take that engine to Sprint Cup competition, and to the street. They also do a lot of behind-the-scenes engine research for GM, and they design some of the GMPP stuff.
      You might find cheaper, but you won't find better.
      jp
      ​John Parsons
      Jun 2009
      Don't want to run a carb but that does look like a nice setup. Almost looks like the second picture has a throttle body on there?
      Both the Bull Run engine and mine are EFI.
      jp
      ​John Parsons
      Mountain View, CA
      Do they have a bit more sedate config?
      True T.
      My blog
      Jun 2009
      jp
      Hahaha, I guess the fuel rails with injectors should have clued me in! Just saw that big air filter on there and made an assumption.
      Awesome looking package, I sent them an email...just waiting to hear back. Do you order directly through Wegner or can you take care of it Frank? I have quite a bit of stuff I want to get through Prodigy so if I can do this too...well why not!
      Jun 2009
      Quote Originally Posted by Damn True View Post
      They list some of their engines here: http://s41657.storefront-solutions.c...?CategoryID=43
      BTW...have enjoyed following your build. Should start a thread of my own, but I feel like a wimp since I just tore it apart some and then sent it to a shop. I know I would never finish if I attempted it.
      Mountain View, CA
      Quote Originally Posted by steelerguy View Post
      Thanks. I live in N. CA. I'd never be able to justify paying for mine if I weren't doing the lions share of the work myself.
      True T.
      My blog
      Dunwoody, GA
      MAST motorsports seems to be doing well too. You can find their banner to the right. DSE has one of their 413s in the 69 Test Car. Wegner is great too though.
      Trey
      ~ Jon Hammond
      Dec 2007
      Carlsbad, Ca
      frank, how complete is the motor for that price?
      Tim
      Tim
      Build Thread Link
      Jun 2009
      Quote Originally Posted by The WidowMaker View Post
      Tim
      I talked to Wegner and they said it was minus the harness.
      May 2002
      Southeastern WI
      jp
      I spied an NHRA Pro Stock motor up there last time I was there. They have a couple of tricks that they are working on for one of the top builders in the Pro Stock world. If it works, it will raise the bar even higher.
      Jeff
      Dec 2007
      Carlsbad, Ca
      thats a pretty good deal for all that. mast is about the same price, but you get the harness and ecu, but no front drive. i guess its about a wash. wegner seems to have the edge with the racing background.
      Tim
      Build Thread Link
