    Page 7 of 10 FirstFirst ... 2 3 4 5 6 7 8 9 10 LastLast
    Results 121 to 140 of 187
      Houston, TX
      hurry up and break out the 1200 grit!!!! LOL
      Looks great.
      Thanks man
      Tu Ho
      Firebird V2-LS swap
      May 2009
      Minnesota
      Looks good. Looks like someone put a A-body rear end in the car. What gears are on the posi unit?
      Houston, TX
      Quote Originally Posted by 68400BIRD View Post
      That's what I thought. But a couple of guys on the firebird forum said that in cars with 400 engine option, Pontiac used heavier duty rear end from A-body. The XE code is supposedly Firebird specifc, so the PO may have just swapped the gears. I hope it stays 3.08 since the car will be a cruiser. I'll check when I open the cover to put on new gasket.
      Tu Ho
      Firebird V2-LS swap
      May 2009
      Minnesota
      That's right. I forgot the 67 models did come with that rear end. I guess my mind is going as I get older. LOL
      Nice....i've been wanting to go the 68 firebird route. Thats coming along nice!
      Feb 2006
      South Austin- Texas
      Hello Tu
      This is Tommy... It was great meeting you today. I'll be in touch now, I'm hook on your project and can't wait to see what else you have in the works. I'll be glad to help if I can, PM me so we can get caught up once you have time and I'll tell you about me 68.
      1968 Windward Firebird 400
      Blk Deluxe Interior 200-4r PS PDB
      Hotchkis Suspension
      Guldstrand Mod
      VSE Shocks - 3-way adj.
      VSE Nyliner Bushings
      LT1 electric fans and Alum Radiator
      Houston, TX
      Hey Tommy,
      It was great to meet you and the guys yesterday. I'll post some new pictures once I get home.
      Tu Ho
      Firebird V2-LS swap
      Jul 2007
      Hey Tu, I met you along with Andy and Tommy on the 15th. The car looks great, and yes I look forward to seeing it finished, as I am sure you are. Take care, have a great Christmas visit, and keep in touch with us HALFers, whenever you can.
      Houston, TX
      Well, here are some updates. I've been working on it off and on since last Thanksgiving.
      Installed new Powermaster mini starter
      Get ready to drop in the engine/tranny
      Engine/tranny went in with no problem. Not having a front end helps.
      Tu Ho
      Firebird V2-LS swap
      Houston, TX
      Mocked up and welded up some adapter brackets to mount the Porsche bucket seats. Much improved over the stock seats. Just have to dye them black.
      Started to dynamat the inside of the car, used up 2 bulk boxes to dynamat, plus a box of trunk kit to finish up the trunk.
      Installed close cell sound insulation over the roof, dash area. I have another 3 boxes of Dynaliner to finish up the floor and firewall.
      Also finish up the braking system. Now i have working brakes.
      Tu Ho
      Firebird V2-LS swap
      Houston, TX
      Started wiring up the car with American Autowire Classic update kit.
      The new fuse box (has about double the number of circuits compared to the old one).
      Installed DSE wiper switch with matching headlight switch
      I've also decided to convert the stock throttle linkage to a cable set up, since the throttle rod is missing. I bought a complete Lokar kit.
      Old gas pedal and brake pad.
      New Lokar billet aluminum set up. I had to enlarge the firewall opening abit for the throttle linkage to fit properly
      Cable linkage/bracket installed at the carb, along with the bracket for the kickdown switch.
      I also upgraded the lighting in the garage, going from 2 compact flourescent lights to 4 4-ft shop lights. Makes a huge difference in lighting quality.
      Next up is finishing up the wiring inside the car, and install the Vintage Air as soon as it comes in from Frank @ Prodigy Custom.
      Tu Ho
      Firebird V2-LS swap
      Mar 2010
      Rochester NY
      Nice Project
      Don
      Grace - 67 Camaro daily driver with upgrades along the way.
      https://www.pro-touring.com/showthre...-Camaro-Driver
      Apr 2008
      Slaughter,LA
      Well just looked thru the whole post and I have to say great job on not only the work but I am very glad to see the great job of task management. You should be a example to all of how to start a job and finish it before moving on to something esle to often this is what happens to these great cars to many small jobs not finished turns a project to a basket case. Again great Job and thanks for taking the extra time to share it with us.
      Houston, TX
      Quote Originally Posted by whayden2003 View Post
      Thanks. I like to start on small jobs on the car. That way I can easily finish it and move on to the next one. The body work on the car took a long time, and I've had to take a break from it. Glad that portion was over.
      Tu Ho
      Firebird V2-LS swap
      Merritt Island,FL
      Tu,
      Just read thru the whole thread, car looks great ! Post some pics of the kicks installed when you get a chance.
      Brian
      Check out my web site.
      Apr 2008
      Slaughter,LA
      Oh and you should change the title of the tread from another firebird project to "THE FIREBIRD PROJECT"
      Jul 2010
      Rancho Murieta
      Awesome Car
      You do really great (and fast) work! this thing looks great! i had a question about the rear end. Is that lower arm on there to prevent axle wrap/wheel hop since it's a mono leaf car?
      Houston, TX
      Quote Originally Posted by Clutch93 View Post
      Clutch93,
      Sorry for not getting back to you sooner. The lower arm on the rear end is to prevent axle wrap. Automatic cars have one, whereas manual equipped cars have 2.
      Tu Ho
      Firebird V2-LS swap
      Houston, TX
      Some update. Been working steadily for the last few months.
      Test fitted the front speakers and Screamin Performance kick panels. The panels are high quality and they fit great.
      Picture of ds closeout panel
      Driver side kick panel with speakers
      Pass side
      Tu Ho
      Firebird V2-LS swap
      Houston, TX
      Installation of Vintage Air A/C
      System as delivered.
      Evaporator unit
      Cut the dash for center vent
      Center vent installed
      Side vents
      Evaporator installed
      Compressor installed. I brought the lines to the local A/C shop and had them crimp the fittings
      Modified the stock HVAC controls for V/A controls
      I tried to install the radio, but the evaporator is in the way. Since radio is just a dummy and not working, I decided to do some surgery on the radio housing. After 5 mins with the cut off wheel, I have this.
      Then everything got mounted up in the center dash. Just have to get a trim plate for the radio.
      Tu Ho
      Firebird V2-LS swap
