    Thread: Door Popper
      Oct 2007
      Marboro, NJ
      Door Popper
      What are you guy's using for door poppers on your shaved doors ? I currently have an autoloc kit and it's nothing but trouble. Looking to swap it out for something that actually works..
      Recommendations ?????
      Joe C
      1969 Camaro
      west michigan
      autoloc is one of the best around. I have had 3 kits with no troubles. is it possible it may be too light of a kit or something? how many pounds of pull did you get?
      Chad Read
      Oct 2007
      Marboro, NJ
      I have to check. They open the door fine, but the selinoid get's stuck. Happened a few times already and started to smoke up the car.
      Joe C
      1969 Camaro
      Des Moines, IA
      I prefer the SPAL shaved door kits. the plunger is coated with teflon so moisture and debris will not corrode the plunger (which is what is causing the "sticking" problem)
      Aug 2009
      California
      I've used Autoloc for years as well. I just picked up their new dual actuator kit. Took half the time to install and the actuator is about 1" thick so I think it fits better.
      Heres the link to the kit I bought. Got em for $50 for the pair and free spring loaded poppers. I think they might have the sale goin' on still
      Oct 2007
      Marboro, NJ
      I have a call into autoloc now to see how to resolve the problem. The drivers door popper sometimes doesn't release. Hopefully they will send me a replacement
      Joe C
      1969 Camaro
