Thread: Suspension help
07-28-2009 #1
New to Pro-Touring
- Jan 2005
- 64
Suspension help
Hi I am working to upgrade my 77 Trans am to handle at elast as anything new short of a Vette on a budget...
Starting with a basically restored car with poly bushings everywhere stock front 1.25 bar and .75 rear ws6 bar. I have QA 1 single adjust shock front and Koni Reds in the back. Stock springs front coils cut 1/2 coil. I am looking at Kuhmo XS 285/17/40 rear and maybe 275/40/17 front on Year ones 17" snowflake rims... I hope the 275-40 fits up front I hear they do but it is tight. My 255/60/15's do rub the sway bar a bit at full lock. Anyway I was looking at solid subframe bushings and maybe new upper control arms for more camber and caster. What about the longer ball joint is it worth doing... I was looking at protouring f-body for the bushings and arms and some I found links to here and most do not include a upper bump stop so I am concerned about over travel at the drag strip. The car has been know to carry the front tires a bit if it can hook....I have welded in subframe connectors and have 1 LE brakes on the front with factory Disk on the back. I figure to upgrade the springs next or maybe swap out the rear to coil spring system rather then spend 900 bucks for good leafs .. ride quality does matter, but is not a major concern I do not want it clunking and banging though....
Thanks for helping a new guy get off to a good start...
