    Results 1 to 20 of 25
      Jul 2009
      Grand Rapids, MI
      Art Morrison G-Max Chassis
      Let's talk chassis' for a bit. As most of these projects do, mine continues to evolve. I've seen a ton of talk around here about Art Morrison so I decided to have a look at their website. I quickly found the G-Max Musclecar Chassis and immediately took an interest. Don't see too much of this kind of stuff for the Mopar A-Body guys. Here's some questions.
      Is a full chassis like this really worth the cost, time, and effort into putting it under a uni-body car? My car isn't a race car, may see some auto-cross for fun but nothing serious, maybe some road course but again, nothing serious. Goal is to build a quality, bullet proof (engine/drive, suspension, etc) car. Next question, can this task be handled in a home garage by someone who is relatively inexperienced when it comes to fabwork but willing to learn?
      The suspension I'm planning to use will run me $5800 which does not include brakes, having my rear-end narrowed, etc. The suspension I'm planning to by is very similar, 4 link rear and coil over front. By the time I add rearend work I'm a little over $1,000 less than the cost of the G-Max. The only downfall is I just installed new floor pans and frame connectors which would end up having been a big waste. My biggest fear is it being over my head when I get it, then I'm at a loss. I don't plan on paying others to build my car, although I'm open to buying pizza, beer, and whatever else for people who are willing to help.
      Thoughts and opinions welcome. I want to get educated on what this type of project takes to do, and do well. Thanks everybody. Will
      Will Ellis
      Build Thread
      Mountain Springs, Texas
      Just noticed you were talking about a Mopar, I should have read closer. Sorry.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Auburn, WA
      Will,
      No doubt it's a big decision.
      Of course nobody can answer if it's worth the cost. If you want the car extremely low while keeping great street manners, this is what you gotta do. Lower CGs allow softer spring rates to maintain the same level of handling, which means a better ride. These chassis also create an extremely ridgid structure, and all the suspension homework is done for you with time and technology that most people can't afford.
      Many of our customers have built cars with these in their own garage. Installing the chassis is actually the easy part: Cut the sheetmetal as needed, then weld the chassis to the rockers (some have use body mounts as well for a modular design). The flat nature of the chassis makes building a floor easy, since all you need is flat tin and a driveshaft tunnel. Some people prefer to take the chassis/body assembly to a fab shop to get the sheetmetal work done.
      The rest involves mounting seats, seat belts, and other items that attach to the floor. Since the body is channeled over the frame by 2-4", you may have to get shorter seat mounts to keep head clearance. Some cars actually have the seat mounting surface almost flush with the top rocker plane anyway, so head clearance may not be an issue at all.
      At the end, you'll have a car that will really stand out from the crowd and you'll have skills that will make other jealous. It's not necessarily difficult work, just takes time.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      I have no experience in fabrication but making this chassis work is fun for me. Of course i have been trying to do this for the last 3 years but thats due to an ever chnaging mind on how I want it done. To me yes it is worth it. It will be a kick ass car when finished. 68 camaro btw with the full max g chassis.
      Jul 2009
      Grand Rapids, MI
      Hey Matt, thanks for chiming in on this. I'm torn and can go either way at this point. I really would like to make the move and do it but I've got quite a few questions yet. If it's better I talk with someone at AM let me know, otherwise if you wouldn't mind (or anyone else for that matter) replying here that would be great.
      On the mopars, the inner fender wells are spot welded to the firewall, how do these mount on the chassis? How do the bumpers mount as well, particularily the front since those bolt through the existing chassis, are those provisions built into the G-Max? Are motor mounts included and placed or is that up to me? Finally, for now, with respect to cutting out the existing floor, does it have to be cut from the firewall to the tail panel, including the trunk and firewall?
      Another question I thought of for you Matt. Have you sold this chassis to anybody building a Chrysler A-Body? I'd love to be able to pick the mind of someone having done or doing a similar project. Unfortunately, Chrysler's can be a bit "special".
      Thanks again for all the replies.
      Will Ellis
      Build Thread
      Oct 2006
      Colorado
      wellis77,
      I'm also building a Mopar-71 Challenger and have spent countless hours looking at the Morrison catalog, site and as many builds with the Max G that I can find. People have done this without the complete floor boards going away. Here's the one that Woodys rod shop built of a Mach 1. Mustangs are at least more similiar on the front clips than say a Camaro. I think to do this you have to compromise the ride height and clearance some.
      Go to SuperRod magazine site and look in their tech archives. There are two PDFs to download of that build plus others. I attached one of them, but I had trouble attaching the first which is mostly of the build.
      http://www.woodyshotrodz.com/project...teinbacher.htm
      I was just looking at mine in the garage. It's stripped and on the rotisserie so pretty easy to visualize these things. I'm not sure if I have the guts or skills to take this on, especially in a two car garage and I'm certainly not a pro builder, but looking at my Challenger I think you should be able to take measurements to the front radiator core support/bumper supports, remove these items and fab this in place or let the inner fenders support the front core support. Most of us Mopar guys already plan on installing a core support brace like the XV unit under the radiator so there's already fab work there. In the back basically the same thing. The bumper/valence rear crossmember ties in to the rails in a basic manner that you should be able to either measure or weld in temp supports to position this for reference.
      The front inner fenders unlike a Camaro are all one piece which makes it a bit more difficult sihce they are part of the "structure". With the Max G there is no need for the shock towers so they come out plus if you're filling any of the multiple holes and/or "bumps" in the inner fenders you might be fabbing alot of this either way.
      The items I think about but don't have answers are of course headroom (I'm 6'2"), pedals---do they need to be shortened? Column to knee room, rear seat since nothing stock is going to fit, of course carpet will be completely custom. How about all the interior kick panels, etc? Mine are hard plastic. Custom/shorter? The tunnel will be modified for the T-56 Magnum anyway.......and that means custom carpet right there.
      Lots and lots of details but I don't think it can't be done in a home garage with the old line---measure twice, cut once. I'd think it would largely depend on how much modification you are currently planning on doing.
      Again, just observations from staring at my project too long and the fact that the big chassis builder names don't have Mopar specific suspension kits (please.....)
      Wes
      Oct 2006
      Colorado
      wellis77,
      I see your signature now includes AME Max-G so does this mean your committed?
      What did you find out about the install?
      Thanks, Wes
      Jul 2009
      Grand Rapids, MI
      Hey Wes, yeah I'm definitely going to do it. I'm not 100% certain how I'm going to mount the body on the frame, weld it or use body mounts, but I've got time for that. I was originally going to purchase all my suspension goodies from Reilly Motorsports but have always wanted to do a full chassis. Building my own is above my skill level but with the G-Max I can handle it. On top of it, the AM chassis is a few grand more but I'm making some of that up in the tranny department. Originally was going to do a TKO-600 from Keisler but I'm going with a t-56 now and will be able to save a bit off the price of a perfict fit. Plus, now that I've got to build a whole new floor, I'm not so concerned about a perfect fit. It's going to be a major learning curve for me no doubt, but I'm up to it, I'm looking forward to it AND it's going to be exactly what I want in the end. Now if I can just find some inexpensive Gen 1 or 2 Viper Calipers for the front and rear...
      Will Ellis
      Build Thread
      I'm using a Morrison chassis welded to my Nova. I'd do it again, as it still seems to me that the only way to get modern car parts on that old car was by sending the entire bottom of my car to Nova heaven.
      Morrison is one of the best, and I talked with them all the time as I built my car. I had Kevin Kosir (x222) in speed dial, lol.
      I did mine in my garage, teaching myself the needed skills as I went. It was one of those "once in a lifetime" projects, and while I'll probably never do it again, I couldn't be happier with the results.
      jp
      ​John Parsons
      Jul 2009
      Grand Rapids, MI
      I've spoken with Kevin myself and will be connecting with him tonight on the quote he sent. Looks like you welded your floor right to the frame? Any particular reason for doing that instead of using body mounts? I'm torn on which way I will go with that piece of it. Both seem to have their advantages. Good looking build by the way.
      Will Ellis
      Build Thread
      NW Oregon
      You can achieve a low stance by modifying the RMS front end and building a triangulated 4 link using brackets from Morrison. Keep your floor which you already replaced. Weld in some subframe connectors.
      My car pic'd has the RMS unit modified to tuck up in the frame and a triangulated 4link.....sits pretty low with the stock floors and coilovers. Full frame would no doubt be very cool, but a ton of work.
      RobS
      71 Demon, 6.1hemi, paddled 4l65e, AlterK, Tri4,
      I welded the car together because I couldn't figure out any possible reason to remove the body later. If you are adding a cage (which I was), then there is no good reason for making the body removable. Also, since I wanted my chassis to be as stiff as possible (both statically and torsionally) make the whole chassis/body a single piece of steel was attractive.
      My car has no rattles, doesn't dolphin, and is unbelievably stiff. I can jack the car at any single point anywhere on it without affecting any body gaps. My doors close the same way no matter how the car is lifted off the ground.
      I doubt I could have that kind of chassis performance with a bolt-on arrangement.
      To each his own, but I'd recommend you weld it together.
      jp
      ​John Parsons
      Jul 2009
      Grand Rapids, MI
      Hey Rob, good to see you over here. I've been keeping tabs on your build at BBD. Making any progress on it of late? Your Demon is incredible by the way. I've gone back and forth and round and round on my setup and I can get the ride height I want with all the RMS stuff, and make the car a bit more stiff with frame connectors, but it won't quite be what I want, so that's why I've only recently decided to go the AM route. The stink is, I really want to send some business Bill's way because he's so standup.
      JP, thanks for your insight. I have to say I "like" the idea of bolting the body of my car to the chassis, but like you I can't think of a reason why I'd ever need to take it off again. The only reason I can think of to bolt it on is for the "possibility" to remove the body at some random point down the road AND to be able to powder coat the chassis. Not exactly great reasons if you ask me, or probably anybody else. Kevin even commented that welding it all is the way to go.
      Will Ellis
      Build Thread
      Oct 2006
      Colorado
      Will you be getting the C6/3-link or the 4-link triangulated configuration?
      That will be a nice ride. I agree, whenever I crunch the numbers it's not that different from the other items on the market for our Mopars.
      Keep us posted.
      Wes
      Jul 2009
      Grand Rapids, MI
      For now going with the triangulated 4 link. May consider the c6/3 link but I need to check it out a bit more. I'll certainly keep everyone posted on my progress. As soon as I get back stateside for a few weeks (in 4 months) I'll get a build thread going.
      Will Ellis
      Build Thread
      Don't forget pictures. We must have pictures.
      jp
      ​John Parsons
      Oct 2006
      Colorado
      Will,
      I've been thinking/looking at the Max G some more. What did you find out about things such as headers? I would imagine these will have to be custom since they most likely need to be "shorter" to align with the exhaust holes throught the frame? I'm also building with a 3G Hemi (6.1L) also so the available aftermarket headers are designed for the most part to hang the exhaust below the body. For the more popular Chevy Max G builds AME makes some of these items. Just pondering the total impact of the frame besides some of the obvious items.
      Wes
      Auburn, WA
      Wes-
      We only make headers for bolt-on chassis only...with those we know exactly where the motor will sit. The customer can place the engine anywhere he wants with the Max-G, making headers impossible. Guys usually have custom ones made, although a guy could use blockhuggers.
      Matt Jones
      Mechanical Engineer
      Oct 2006
      Colorado
      Matt,
      Thanks for the input. I figured the same. The 3G Hemis don't have a lot of options on the headers so it would probably have to be custom.
      Wes
      Jul 2009
      Grand Rapids, MI
      Wes, S & P has a set of headers that look like they'll fit. Only one way to find out. I thank that's the route I'll be going and if they don't work I'll do custom.
      Will Ellis
      Build Thread
