    Results 1 to 20 of 23
      Rochester, MN
      Help - Size of wheels for Chevelle
      Hello,
      I have been looking at buying a set of wheels for my 72 SS chevelle and wondered if anyone knew what I can fit with stock Tubs.
      18x10 ? 19x10 ? 19x12 ? Rear
      18x10 ? 18x8 ? Front?
      thank you for any advise
      Chris
      Jul 2009
      Merchantville, NJ
      I think the same as my GTO, 10" max rear, 11" POSSIBLY with some massage and on the front 8" I have seen, but that is it. others can chime in, still looking for rims for my 68 GTO, so basically same body. I have a set of 15" Centerlines and tires for sale in New Jersey for $500 :-)
      1968 GTO 467 ported Pontiwreck, 9", 5-Speed
      2000 Viper GTS, 10Lb SC, Roller Cam, Fully Ported
      2008 Viper SRT-10 Coupe, Stock, FOR SALE
      2008 Grand Cherokee, 3" OME Lift, armor/winched
      2006 Votes thanks to Acorn
      May 2008
      SoCaL-Pico Rivera
      from the research and phone calls I have made (site sponsors)
      you can run a 9" wide up front and a 10 out back with no problem. 11" out back would be a tight squeeze and would require no margin for error.
      I will be running 20 x 10 with a 315/35 20 and up front 19 x 9 up front with a 275/35-19.
      https://www.pro-touring.com/forum/sh...ad.php?t=57307
      Rochester, MN
      Thank you!
      Thank you for the info. Much appreciated.
      Aug 2003
      8s and 10s are very comfortable, but we have pushed it to 9s and 11s.
      We have 18 X 8 and 18 X 10.5 on the Bull Run Racer, We wanted a little more rubber around the rim on the Bull Run car due to the bad roads we knew we would encounter on the 3000 mile race, we wanted the cushion for our backs and the rims. So we went with 245/ 45 /18 Front and 285 / 40 / 18 rear. Chevelle (A Bodies) soak up these taller tires pretty easy with their large wheel wells.
      Here is that Bull Run Racer described above. if I can be of any help feel free to call.
      Jun 2006
      Long Island
      I am running an 18x9 with 275/35/18 up front and on the rear I am running an 18x10 with 295/30/18. I don't have any issues and I think I could go a little bigger on the rear if I wanted to.
      Jul 2010
      Quote Originally Posted by 72 GOAT View Post
      What backspacing and wheel?
      Nov 2010
      Detroit
      Yes a 18x10 will fit using a 5.5 inch backspacing with no problem
      Oct 2005
      Corona, CA
      You can run a 9" upfront with a 275 and a 10" outback with up to 305. Pretty much our standard setup for the 68-72 A Bodies.
      Monterey Peninsula
      Quote Originally Posted by Justin@DriverzInc View Post
      Exactly what Driverzinc set me up with 18x9/18x10 275/35/305/35 w/5.5 front b/s & 5.75 rear b/s...fit's like a charm.
      www.buickfunnycar.com
      Mantorville, MN
      275s on a 9.5 up front, and 315s on an 11 in the rear... careful measuring, and good lateral-location of the axle.
      Derek Kiefer,
      Mantorville, MN
      Nov 2010
      Someone should sticky this information!
      Marshall , MO
      I've been posting this for a while http://www.carcraft.com/techarticles...els/index.html the info is old but still relevant the biggest wheels they used in the article are 17's. For every 1" added in rim size go down 1 series size. This will keep the overall diameter roughly the same IE. 275/40/17 is roughly the same as 275/35/18. I also use this http://www.miata.net/garage/tirecalc.html to help figure overall tire diameter of different size tires.
      Brad Shepard
      69 Malibu
      Marshall, MO
      Jun 2009
      N.Nevada
      19x10 and 18x8 will fit with ease.
      Quote Originally Posted by cp72ss View Post
      Hello,
      Chris
      462 Doug Nash 5 Speed Centerforce Clutch Quicktime Bellhousing Edelbrock Heads Solid Roller Holley HP Victor Intake Pump Gas 66 12 Bolt Poly Bushings Hotchkis Springs Metco Control Arms Big bar front Stock rear bar INTRO 20's & 19"s
      Aug 2003
      We just did 20 X 11 Forgelines on a 1970
      Jul 2010
      Quote Originally Posted by ProdigyCustoms View Post
      All stock? Fronts?!!!! Nice!
      Aug 2003
      Quote Originally Posted by Addicted View Post
      19 X 8.5 front. Stock chassis, air ride.
      Jul 2008
      ^^^^^^^That is HOT!
      Mark Pearce
      Vini Vidi Vici
      RI
      I fit a 17x9.5 with a nitto drag radial 315/35-17 on a 5.5 backspacing front and rear. Im actually going to try to fit a 11" or 12" wide rim in the back with a 335. I think I have enough room. Take plenty of measurments.
      Frank M
      1970 lemans sport
      2005 srt-10 ram
      http://www.youtube.com/watch?v=SER1gBLn2N0
      Dec 2007
      Lombard, IL
      Hey Frank! Somebody stole the doorhandles, and side markers off that Chevelle!
      Looks Awesome!
      Dan
      1971 Chevelle Maliboo Convertible 496/4L80E
      1956 210 2 door Sedan 8-71 blown 468/T400
