Results 1 to 11 of 11
Thread: 4L80E, Tuning Help
07-22-2009 #1
4L80E, Tuning Help
Hey Guys,
Got reacquainted with a fellow gearhead tonight. He tells me that he's put a 4L80E in the car. He cannot get the tune right and there seems to be no one here who can help him and the TCI help line didn't pan out for him( I didn't ask for the details.
I told him that I would ask the collective knowledge of Lateral-g for help.
Here is the specs:
1956 Chevy
502 (500 - 550hp @ crank ) naturally aspirated
4:56 gears
4L80E is stock gearing, the tranny shop put in a "stage 2 shift kit"
TCI computer and harness
All he wants is a factory tune that will behave predictably. Here are 2 symptoms of the tune:
- when he gets on the throttle, the trans will not shift unless he lifts the throttle.
- when he is rolling @ 5 - 8 mph, and he ratchets down to first gear, the car almost comes to a complete stop. He says it feels like its going to throw him through the window.
Those are the basics, hope that you Guys can maybe give us a hand.
Thanks.Jason
Buick Motorsports aka No Mercy Motorsports.
1985 Buick Regal, Pro-Touring inspired to start. Full on pro-touring as time and money permit.
07-22-2009 #2
- Apr 2009
- 113
Sounds like he has something off a bit on the tune for the WOT upshift but tell him to very carefully inspect the shift linkage/adjustment.
A 4L80E with the extra detent, using the normally supplied shifter lever on the trans, has the lever pulled back at such an extreme angle that shifting from 1-2 can be problematic. The cable is no longer pushing on the lever in the center of it's arc, it's pushing on it near the end and it makes for an almost straight line, so most of the force is going straight and not moving the lever.
Also ANY slop in the linkage creates problems. I've had to weld the pieces together that are normally bolted so they would have zero slop.
The valve body kit (if they used TransGo) has you restrict the feed to the low band. Many builders omit this step. Admittedly the method looks archaic but it does prevent harsh 2-1 shift.
I wouldn't shift it manually to low gear under decel until stopped.
