      Fenton, MO
      Fixing a Striped Air Cleaner Stud
      Whats the best way to repair striped threads in a holly where the air cleaner stud goes.
      Jul 2002
      Mesquite, TX
      I would think a Helicoil or similar, but I am not sure that they make them that small?
      I guess you could drill it out and tap it to the next size and just use threaded stock instead of the normal rod, but you'd have to come up with a larger hold-down nut.
      Florida
      If you've got room to drill and tap it for a heli-coil thats a good route. You could also go to a local home improvement store and find the next size "all-thread" and go to that size. Again drilling and tapping.
      Good luck!
      "Give me a lever long enough and a place to stand, and
      I will move the earth."
      --Archimedes
      Jul 2002
      Muskegon, MI
      This might not be the best method but what about JBweld or some sort of epoxy. Just a long shot and again not the best method to repair it.
      Fenton, MO
      Quote Originally Posted by CAMAROBOY69
      I though about that but then if I ever want to change air cleaners what would I do lol....
      Nov 2003
      Paradise, Ca
      My vote is to use a heli-coil. Whatever you do, be sure to take the carburetor off the motor and either take it fully apart, or tape up everything except the aircleaner stud hole so no aluminum gets in the carburetor/motor.
      -Matt
      Fenton, MO
      Yeah I will be pulling the carb no matter what I do.... thanks im gonna talk to the shop about putting a helicoil in it.
