    Thread: Help Please!!!!
      Jun 2009
      Spring, Texas
      Help Please!!!!
      I have a brake question....
      The brake warning light in the speedo on my 69 GTO comes on when the car gets to operating temp. The brake pedal feels solid, NOT spongy...When the car cools down, the light goes out until it warms up again. I am running long tube headers, and the headers are a good 2-2.5 inches from the proportioning valve. The fluid level in the M/cyl is fine. Are my headers causing the proportiong valve to heat up, and possibly cause my problem? The headers were installed as part of my engine rebuild, I was running Factory RA III manifolds before, and I never had this problem....
      Any suggestions?
      Oregon
      I'm guessing here, but it's possible that the contact switch that signals the brake balance dummy light on the dash cycling due to the temperature fluctuations. You could slip a temporary heat shield in place between the header and combination valve to test that theory pretty easily.
      Tobin
      KORE3
      It's what I does.
