    Results 1 to 9 of 9
      Apr 2004
      Cedar Rapids, IA
      Lower perch jig for Guldstand mod
      I have seen where some of you guys have cut and lowered your perches to do the Guldstand mod.
      I couldn't find any pics doing a search. Anyone have any?
      Central CA USA
      I did mine sorta freehand, but used reference marks on the subframe to go by.
      If I did it again, I think I'd make up a plate with both hole patterns on it and a couple of 1" spacers just to keep the plate away from the mount for welding room. Then I'd bolt the plate to the upper mount and tack weld it to the subframe, cut the oem mount off and section it, bolt it onto the lower holes and weld it back in place. I'd position the jig plate so it was out of the way of where you need to cut the mount off.
      San Rafael
      Template
      I used this template. Hope this might help
      http://img57.imageshack.us/i/guldstr...ate001kw3.jpg/
      Paul
      The template seems to be ever changing. This one lowers is .75", and was from a PHR article just a couple years ago.
      http://www.popularhotrodding.com/tec.../photo_08.html
      May 2009
      Houston
      If anyone has a good template or scan with measurements so one could be made in autocad, I could spend a little time in autocad so the site could have a digital copy.. if someone could grab a measurement center to center of the original holes, I could probally use the can that smhigh posted. just throwing it out there..
      clint
      May 2009
      Houston
      Well I traced Dave Pozzi's picture in autocad, put some dimensions on it and I printed it to pdf. I dont have a printer to test print anything, but acrobat professional has a measure tool. Acording to the measuring tool, its spot on. sent a PM to Dave Pozzi and make sure its ok if I post it up a reproduction of his drawing.
      Central CA USA
      Mine is vintage 1973, direct from Guldstrand's engineer. It has a little more anti-dive than the current one, the rear hole is lowered around 1" instead of 3/4".
      Do what you want to the drawing, but each persons printer is going to print it out at slightly different size anyway, same with photocopiers, some shrink, some enlarge the image. The template on my page was redrawn by me with mechanical drawing software and prints out fine on my Epson printer and Mac.
      May 2009
      Houston
      Ah, here is the pdf... maybe someone with a printer can print a copy and see how it prints out.
      clint
      Apr 2004
      Cedar Rapids, IA
      David, thanks for the reply and the tips. I know I have seen others lower their perches and post pics. I seem to remember other having issues with the shock support.
