    Results 1 to 9 of 9
      McMurdo Station, Antarctica
      Search Difficulties
      I tried to search for 'Z06' in the Wheels section and I recieved no matches to the search. However I did find at least a few post with Z06 mentioned in them on my own. Am I doing something wrong? Or is the search not picking up on these threads?
      Thanks for the help.
      R.J.
      Jun 2002
      Long Island, NY
      R.J.,
      You're not doing anything wrong. I just tried several different ways and I could not get the search feature to pick up any thread with Z06. I did however get 313 responses from Corvette. On a hunch, I tried searching for "Z" and nothing came up either. I think the search function may be word sensitive only and will not pick up anything that it does not recognize as a word.
      Jun 2002
      Long Island, NY
      I just tried searching Z28 with no results, and also 69 with no results. However, 69 Camaro yielded several results, but not for 69, just for Camaro. Z06 Corvette also yielded a number of threads, but for both searchs, it stated: The following words are either very common, too long, or too short and were not included in your search: Z06. (69 for the Camaro search) I'm pretty sure that the search feature will only return results for word searches.
      Jul 2002
      Mesquite, TX
      Search terms must be at least four characters long - any shorter and it's ignored by the search engine.
      Apr 2002
      I find it annoying I cannot search for anything containing a number. Here's a brief list of failed searchs:
      "10 bolt gears"
      "8.5 inch"
      Can you modify the search engine to allow those?
      --JMarsa
      Jul 2002
      Mesquite, TX
      It's not the number - it's the length of the search term. A search for "1968", for example, is long enough to work.
      Ralph/Larry, can the minimum keyword length be adjusted, or is it not configurable?
      Jun 2002
      Long Island, NY
      I think the minimum length per VBB is 3 digits, but I'll try and play around with some settings tonight and see if I can change it.
      Jan 2000
      Thousand Oaks California
      I just changed the search to allow a minimum of three digits instead of four. This should help.
      Larry Callahan
      Thanks Guys. I'll try it again today.
      R.J.
